Transferring files from Android phone (via USB)
Question
My Android phone is visible in "Devices" (GUI, default Debian MATE) only in PTP transferring mode (only media files).
When I switch (on phone) to "File Transfer" mode (mtp - Media Transfer Protocol, if I understand correctly) - the device disappears.
What could be the problem?
Did you try installing go-mtpfs and gmtp?
Quote:Did you try installing go-mtpfs and gmtp?
Unfortunately, did not help
Have you tried Android File Transfer?
(02-03-2020, 07:16 AM)tophneal Wrote: Have you tried Android File Transfer?
Error "No MTP device found" (message box) at startup.
I installed libmtp-runtime, connected my Sony XZ2 Compact (Android 10) and it showed up when I connected to the USB3 port (next to USB-C).
I didn't even use mtp-detect.
https://www.howtoforge.com/tutorial/how-...-on-linux/
(02-05-2020, 03:52 PM)jiyong Wrote: I installed libmtp-runtime, connected my Sony XZ2 Compact (Android 10) and it showed up when I connected to the USB3 port (next to USB-C).
Unfortunately libmtp does not see my smartphone:
Listing raw device(s)   No raw devices found.
I tried with another phone (Galaxy A6 +): it works.
Probably the problem is in my device (XPeria XA2 Plus Dual, AOSP build). But with other computers (Ubuntu x86_64 and Windows 10) everything works correctly.
There is no problem in Manjaro ARM (XFCE)
Default Debian and a OnePlus phone is pretty much plug and play
https://i.imgur.com/bTvf8ZU.png
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 2,611 10-08-2022, 11:03 AM
Last Post: omarcomputing
  Chromium browser on PBP can't upload files on websites Wawe 0 3,417 07-03-2020, 11:06 AM
Last Post: Wawe
  Debian: How to get kernel header files crusty 2 7,053 01-08-2020, 02:22 PM
Last Post: muma
  Run Linux desktop as an Android application Vasant 7 15,961 11-13-2019, 02:14 AM
Last Post: Wizzard
