Sound driver 32bit sample format not working, some freezes and crashes through ALSA
I got a new PinebookPro last week and did not change much except installing jackd 2.
I noticed that the sound was totally wrong, not in a distorted sense but technically wrong. After some investigation, actually some hours with ALSA devs in freenodes #alsa channel, they came to the conclusion, that there is some need for clarification and/or work to do.
Bottom line question is:  Does the PinebookPro hardware support the 32bit float sample format?
If yes there is something wrong with the driver.
What follows is a curated alsa report summary with annotations from the alsa devs.
I hope this information will be useful in creating a better software revision for units shipped in the future:
[color=#000000]`aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:es8316spksound /dev/urandom` *sympbolic card name does not work `aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:0 /dev/urandom` *no front pcm `aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:0 /dev/urandom` *system crash and reboot when accessing alsa directly with pulseaudio running `pasuspender -- aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:0 /dev/urandom` *conflict between sample bits and sample format ACCESS:  MMAP_INTERLEAVED RW_INTERLEAVED FORMAT:  S16_LE S24_LE SUBFORMAT:  STD SAMPLE_BITS: [16 32] FRAME_BITS: [32 64] `pasuspender -- aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S32_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:0,0 /dev/urandom` Playing raw data '/dev/urandom' : Signed 32 bit Little Endian, Rate 48000 Hz, Stereo HW Params of device "hw:0,0": -------------------- ACCESS:  MMAP_INTERLEAVED RW_INTERLEAVED FORMAT:  S16_LE S24_LE SUBFORMAT:  STD SAMPLE_BITS: [16 32] FRAME_BITS: [32 64] CHANNELS: 2 RATE: [8000 96000] PERIOD_TIME: (333 8192000] PERIOD_SIZE: [32 65536] PERIOD_BYTES: [256 524288] PERIODS: [2 4096] BUFFER_TIME: (666 16384000] BUFFER_SIZE: [64 131072] BUFFER_BYTES: [256 524288] TICK_TIME: ALL -------------------- aplay: set_params:1299: Sample format non available Available formats: - S16_LE - S24_LE `pasuspender -- aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --mmap --device=hw:0 /dev/urandom` (09:59:40 AM) nilshi: that crashed *mmap makes the machine reboot sometimes and other times hang up temporarily *summary the driver has numerous issues[/color]
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,883 04-04-2026, 08:00 AM
Last Post: qingss0
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 3,563 11-22-2023, 11:47 AM
Last Post: fxc
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 3,071 07-13-2023, 01:50 PM
Last Post: PaulQ
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 2,383 12-09-2022, 04:48 PM
Last Post: River
  Pinebook Pro freezes when running on battery petaramesh 5 7,727 09-22-2022, 12:43 AM
Last Post: petaramesh
  alarming sound coming from pinebook pro jazzhands 2 4,444 08-21-2022, 02:34 PM
Last Post: foobar
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 6,627 06-29-2022, 02:00 PM
Last Post: Chief
  Article: Build a Linux Driver for PineDio LoRa SX1262 USB Adapter lupyuen 3 7,307 05-26-2022, 11:09 PM
Last Post: lupyuen
  My Experience Using the Pinebook Pro as a Daily Driver warpnow 9 17,740 06-22-2021, 02:30 PM
Last Post: moonwalkers
  If booted with headphones in, sound comes from them and speakers stozi 6 11,104 06-11-2021, 01:27 AM
Last Post: dsimic
