Trackpad firmware update
#81
Do the MrFixIt scripts now cover this trackpad prom update, or do we December deliveries still need to do this upgrade please?
#82
(12-17-2019, 07:44 PM)jcj52436999 Wrote: Do the MrFixIt scripts now cover this trackpad prom update, or do we December deliveries still need to do this upgrade please?
If you're getting a PBP in December 2019 then the trackpad update is already flashed to the keyboard SPI.
#83
My darling PBP won't restart after the first reboot. I followed the instructions to the letter. Green LED is on, screen is blank (no backlight). *sigh* I'm clueless on this.
#84
(12-18-2019, 11:49 PM)Watercourse Wrote: My darling PBP won't restart after the first reboot. I followed the instructions to the letter. Green LED is on, screen is blank (no backlight). *sigh* I'm clueless on this.
I suggest you join the #Pinebook chat and get support there - it will be easier to walk you through troubleshooting 'live'
#85
Tremendously helpful (and not at all judgy) folks were a BIG help in getting my PBP back in working order. And that, in a nutshell, is why i bought a Pinebook Pro.
Thanks!
#86
Tell us what happened and how it was solved (in the case someone else experience the same issue)
#87
(12-20-2019, 07:42 AM)Kochise Wrote: Tell us what happened and how it was solved (in the case someone else experience the same issue)
Or better yet, please add as a troubleshooting step to wiki... thanks Smile
#88
Do the Mr Fixit software 'updates' install the keyboard and touch pad firmware updates  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
#89
Nope, he doesn't bundle the update software because 1) its not that easy to 'auto-install' the keyboard firmware and 2) users with PBPs starting Dec 2019-onwards will not need the new keyboard firmware as it will be flashed at factory (and its not ideal to have people re-flash a SPI chip for no reason).
#90
Thanks !
There is 'A'  SPI chip on the keyboard  ?
(Not 'THE'  SPI chip on the motherboard ?)
I got a new usb keyboard to do the keyboard/track pad firmware installation,  (as discussed a while back)
BUT,  I have been putting it off, hoping for a simpler method to show up.
Thanks Again
When will those ANSI replacement keyboards become available ?
I am assuming those will also have the latest firmware when they DO become available.... (?)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,230 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,049 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,063 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,962 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,327 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,426 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,100 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 5,977 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,381 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,591 10-19-2021, 01:57 AM
Last Post: j4n3z
