Bluetooth - how to connect headphones?
I am running Q4OS with the Openbox window manager.
What is the best/easiest way to pair and connect to Bluetooth headphones?
(12-27-2018, 10:48 AM)jschall Wrote: I am running Q4OS with the Openbox window manager.
I am not using Q4OS but Manjaro but I had to install these packages:
- bluez-utils
- pulseaudio-bluetooth
And then I could use blueman to set things up.
- blueman
The names of the packages can be different but you could give it a try.
Thank you, Surehand53.
I did that, and paired to my headset, but when I select connect to headset/handsfree/audio sink, nothing happens. No error message.
(12-31-2018, 10:10 AM)jschall Wrote: Thank you, Surehand53.
You could use the tool bluetoothctl, you should have installed that with the other packages.
However it is not the most straight foreward tool too be honest.
A description is here:
https://wiki.archlinux.org/index.php/Bluetooth#Pairing
I got it working like that but it needed a bit fiddling.
You might get some useful error messages at the very least.
  How to remove pinebook WiFi and Bluetooth hardware chip Shoananas 2 7,362 06-18-2019, 03:00 AM
Last Post: ThomasFink
  pinebook onboard bluetooth adaptor not found at all dkebler 1 4,462 11-05-2017, 11:33 AM
Last Post: dkebler
