How to disable DHCP address in Debian
I have been pulling off my hairs for more than one day.
I managed to set-up a static IP address in /etc/networks/interface.d/eth0 but Debian insists on setting also a dynamic address.
How can I tell the system that I am a big boy, i know what I am doing and I would really really prefer it does not try to hold my hand, because all it does is having me trip over.
I need to set-up a static IP and only that static IP, because that is the only IP that I can use to access internet. But with the dynamic IP, all connections are initiated using that dynamic IP and the firewall will not let the connection pass through.
As I am using the latest Debian image, it has no GUI, so all I have is command line, and I can't figure out what to do.
Thanks in advance,
Olivier
I followed this guide which setup netplan.
https://websiteforstudents.com/configure...8-04-beta/
(11-01-2018, 01:49 PM)frewind Wrote: Hi,
Thank you, I had a look, but the minimal Debian kernel does not have netplan installed.
I am in a chicken and egg situation, as I cannot install anything until I have figured out how to configure the network.
In fact, after I flashed Debian anew, I see that I have 2 dynamic IPs associated to eth0.
I tried to remove anything from /etc/network/interface and /etc/netplan and reboot, but I still have two dynamic IPs.
Olivier
Do you have a
/etc/dhcpcd.conf
if so
interface eth0 static ip_address=192.168.1.99/24 static routers=192.168.1.1 static domain_name_servers=192.168.1.1
  Freezes and kernel panics with Debian trixie jssfr 4 4,347 04-15-2026, 06:48 PM
Last Post: prahal
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,978 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 3,109 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,212 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 6,674 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 6,478 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 7,784 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 18,361 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 4,735 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,907 09-30-2021, 11:54 AM
Last Post: publiclewdness
