[SOLVED] No sound from phone-jack via "es8316" on rockpro64
The environment is "bionic-lxde-rockpro64-0.7.9-1067-arm64.img.xz".(https://github.com/ayufan-rock64/linux-b...m64.img.xz)
kernel is updated to "linux-image-4.4.138-1094". (https://github.com/ayufan-rock64/linux-k..._arm64.deb)
The sound via hdmi is output well.
However, there is no sound via "es8316", but somehow rubbish comes out on the serial console.
Is there a person who has successfully outputted sound via "es8316" ?
Moin!
Just wanted to say that you are not allone: Same problem here.
Greetings, J.
As a result of various investigations,
These problems turned out to be caused by the kernel side.
The issues is as follows (0.7.9: gitlab-ci-linux-build-67: 4.4.132-1075)
1. "es8316-sound" no sound.
2. "spdif-sound"  no sound.
3. "serial-console output" contains garbage.
All of the above issues have been solved by modifying kernel.
*Additional information)
 At currently the newest kernel (4.4.154-1122),
 all sound (in addition to the above, "hdmi-sound" also) can not output.
I also confirmed that it works correctly with the same modification.
(10-05-2018, 12:23 AM)t4_4t Wrote: As a result of various investigations,
I agree with your findings on 4.4.132 & 4.4.154 kernels - what mods do youu apply to the kernel to correct things?
Just upgraded to 4.4.154-1122 and have the same issue here as well.
OK - still trying to get some noise out of my ES8316. Think I am pretty close but help/suggestions required, please!
I am compiling my own 4.19 kernel: Ayufan versions have no ALSA devices at all. I now have
chris@rpro64:~$ uname -a Linux rpro64.dukla.net 4.19.0 #3 SMP PREEMPT Wed Oct 24 10:47:48 BST 2018 aarch64 aarch64 aarch64 GNU/Linux chris@rpro64:~$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: rockchipes8316c [rockchip,es8316-codec], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 []   Subdevices: 1/1   Subdevice #0: subdevice #0
Which is quite promising. Also
$ aplay -L null     Discard all samples (playback) or generate zero samples (capture) default:CARD=rockchipes8316c     rockchip,es8316-codec,     Default Audio Device sysdefault:CARD=rockchipes8316c     rockchip,es8316-codec,     Default Audio Device dmix:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Direct sample mixing device dsnoop:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Direct sample snooping device hw:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Direct hardware device without any conversions plughw:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Hardware device with all software conversions
But
$ speaker-test -c 2 sysdefault:CARD=rockchipes8316c speaker-test 1.1.6 Playback device is default Stream parameters are 48000Hz, S16_LE, 2 channels Using 16 octaves of pink noise Playback open error: -22,Invalid argument
And then system log fills with
[   83.424483] es8316 1-0010: No sysclk provided [   83.425020] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22
I did remember 0010 in an error message earlier in the boot:
$ dmesg | grep ff880000 [    2.090028] rockchip-pinctrl pinctrl: pin gpio4-0 already requested by 1-0010; cannot claim for ff880000.i2s [    2.090907] rockchip-pinctrl pinctrl: pin-128 (ff880000.i2s) status -22 [    2.092501] rockchip-i2s ff880000.i2s: Error applying setting, reverse things back [    2.093180] rockchip-i2s: probe of ff880000.i2s failed with error -22
So the question - how to sort the 1-0010 | gpio4-0 | ff880000.i2s conflict? Pretty sure this is in the device tree somewhere but have yet to find something obvious.
The problem of "es8316" is quite tough and can not be solved by only modifying "*.dts" or "kernel-config".
For example, your proposal is,
> So the question - how to sort the 1-0010 | gpio4-0 | ff880000.i2s conflict ?
If you fix it, you can surely see some improvement.
However, this kind of modification alone is not enough,
and only the effect of reducing errors from the "boot-log" is obtained.
In order for "es8316" to work correctly, both "dts" and "*.c source-code" modifications are necessary,
and the modification is more extensive (perhaps, more than you think).
"original-kernel (4.19.0-1073-ayufan)"
https://github.com/ayufan-rock64/linux-m..._arm64.deb
$ uname -a Linux Rock64 4.19.0-1073-ayufan-ga6e013135a6e #1 SMP PREEMPT Tue Oct 23 09:19:54 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux [   16.057479] rockchip-pinctrl pinctrl: pin gpio4-0 already requested by ff880000.i2s; cannot claim for 1-0010 [   16.059298] rockchip-pinctrl pinctrl: pin-128 (1-0010) status -22 [   16.060034] rockchip-pinctrl pinctrl: could not request pin 128 (gpio4-0) from group i2s-8ch-mclk  on device rockchip-pinctrl [   16.061258] es8316 1-0010: Error applying setting, reverse things back [   16.062080] es8316: probe of 1-0010 failed with error -22 $ aplay -l aplay: device_list:270: no soundcards found... $ aplay -L default    Playback/recording through the PulseAudio sound server null    Discard all samples (playback) or generate zero samples (capture) pulse    PulseAudio Sound Server $ pactl list sinks Sink #0        State: IDLE        Name: auto_null        Description: Dummy Output        Driver: module-null-sink.c        Sample Specification: s16le 2ch 44100Hz        Channel Map: front-left,front-right        Owner Module: 10        Mute: no        Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB                balance 0.00        Base Volume: 65536 / 100% / 0.00 dB        Monitor Source: auto_null.monitor        Latency: 2213366 usec, configured 2000000 usec        Flags: DECIBEL_VOLUME LATENCY        Properties:                device.description = "Dummy Output"                device.class = "abstract"                device.icon_name = "audio-card"        Formats:                pcm
"original-kernel" with "modified-dts" (your proposal, perhaps what you tried to do)
$ uname -a Linux Rock64 4.19.0-1073-ayufan-ga6e013135a6e #1 SMP PREEMPT Tue Oct 23 09:19:54 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux [   10.538432] asoc-simple-card es8316-sound: ASoC: no source widget found for MICBIAS1 [   10.539291] asoc-simple-card es8316-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack [   10.540228] asoc-simple-card es8316-sound: ASoC: no sink widget found for IN1P [   10.540973] asoc-simple-card es8316-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P [   11.978401] es8316 1-0010: ASoC: Differential Mux DAPM update failed: -6 [   11.979565] es8316 1-0010: ASoC: Digital Mic Mux DAPM update failed: -6 [   13.149657] es8316 1-0010: ASoC: Differential Mux DAPM update failed: -6 [   13.151011] es8316 1-0010: ASoC: Digital Mic Mux DAPM update failed: -6 $ aplay -l **** List of PLAYBACK Hardware Devices **** [  280.461123] es8316 1-0010: No sysclk provided [  280.464960] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22 ... [  280.507795] es8316 1-0010: No sysclk provided [  280.511685] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22 card 0: rockchipes8316c [rockchip,es8316-codec], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 []   Subdevices: 1/1   Subdevice #0: subdevice #0 $ aplay -L [  347.616981] es8316 1-0010: No sysclk provided [  347.620827] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22 ... [  347.663448] es8316 1-0010: No sysclk provided [  347.667337] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22 default     Playback/recording through the PulseAudio sound server null     Discard all samples (playback) or generate zero samples (capture) pulse     PulseAudio Sound Server sysdefault:CARD=rockchipes8316c     rockchip,es8316-codec,     Default Audio Device dmix:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Direct sample mixing device dsnoop:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Direct sample snooping device hw:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Direct hardware device without any conversions plughw:CARD=rockchipes8316c,DEV=0     rockchip,es8316-codec,     Hardware device with all software conversions $ pactl list sinks [  129.097332] es8316 1-0010: No sysclk provided [  129.097841] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22 ... [  129.110316] es8316 1-0010: No sysclk provided [  129.110825] es8316 1-0010: ASoC: can't open codec ES8316 HiFi: -22 Sink #0         State: IDLE         Name: auto_null         Description: Dummy Output         Driver: module-null-sink.c         Sample Specification: s16le 2ch 44100Hz         Channel Map: front-left,front-right         Owner Module: 11         Mute: no         Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB                 balance 0.00         Base Volume: 65536 / 100% / 0.00 dB         Monitor Source: auto_null.monitor         Latency: 2216568 usec, configured 2000000 usec         Flags: DECIBEL_VOLUME LATENCY         Properties:                 device.description = "Dummy Output"                 device.class = "abstract"                 device.icon_name = "audio-card"         Formats:                 pcm
"my-kernel"
$ uname -a Linux Rock64 4.19.0-1073-ayufan-ga6e013135a6e #1 SMP PREEMPT Tue Oct 23 20:05:55 JST 2018 aarch64 aarch64 aarch64 GNU/Linux [    3.683845] asoc-simple-card es8316-sound: ES8316 HiFi <-> ff890000.i2s mapping ok [    3.684589] asoc-simple-card es8316-sound: ASoC: no DMI vendor name! [    3.691358] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok [    3.692034] asoc-simple-card spdif-sound: ASoC: no DMI vendor name! [    4.254556] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok [    4.255369] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name! [    4.500561] ALSA device list: [    4.500561]   #0: ROCKCHIP,ES8316 [    4.500561]   #1: ROCKCHIP,SPDIF [    4.500561]   #2: ROCKCHIP,HDMI $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: ROCKCHIPES8316 [ROCKCHIP,ES8316], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 []   Subdevices: 1/1   Subdevice #0: subdevice #0 card 1: ROCKCHIPSPDIF [ROCKCHIP,SPDIF], device 0: ff870000.spdif-dit-hifi dit-hifi-0 []   Subdevices: 1/1   Subdevice #0: subdevice #0 card 2: ROCKCHIPHDMI [ROCKCHIP,HDMI], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 []   Subdevices: 1/1   Subdevice #0: subdevice #0 $ aplay -L default     Playback/recording through the PulseAudio sound server null     Discard all samples (playback) or generate zero samples (capture) pulse     PulseAudio Sound Server default:CARD=ROCKCHIPES8316     ROCKCHIP,ES8316,     Default Audio Device sysdefault:CARD=ROCKCHIPES8316     ROCKCHIP,ES8316,     Default Audio Device dmix:CARD=ROCKCHIPES8316,DEV=0     ROCKCHIP,ES8316,     Direct sample mixing device dsnoop:CARD=ROCKCHIPES8316,DEV=0     ROCKCHIP,ES8316,     Direct sample snooping device hw:CARD=ROCKCHIPES8316,DEV=0     ROCKCHIP,ES8316,     Direct hardware device without any conversions plughw:CARD=ROCKCHIPES8316,DEV=0     ROCKCHIP,ES8316,     Hardware device with all software conversions default:CARD=ROCKCHIPSPDIF     ROCKCHIP,SPDIF,     Default Audio Device sysdefault:CARD=ROCKCHIPSPDIF     ROCKCHIP,SPDIF,     Default Audio Device dmix:CARD=ROCKCHIPSPDIF,DEV=0     ROCKCHIP,SPDIF,     Direct sample mixing device dsnoop:CARD=ROCKCHIPSPDIF,DEV=0     ROCKCHIP,SPDIF,     Direct sample snooping device hw:CARD=ROCKCHIPSPDIF,DEV=0     ROCKCHIP,SPDIF,     Direct hardware device without any conversions plughw:CARD=ROCKCHIPSPDIF,DEV=0     ROCKCHIP,SPDIF,     Hardware device with all software conversions default:CARD=ROCKCHIPHDMI     ROCKCHIP,HDMI,     Default Audio Device sysdefault:CARD=ROCKCHIPHDMI     ROCKCHIP,HDMI,     Default Audio Device dmix:CARD=ROCKCHIPHDMI,DEV=0     ROCKCHIP,HDMI,     Direct sample mixing device dsnoop:CARD=ROCKCHIPHDMI,DEV=0     ROCKCHIP,HDMI,     Direct sample snooping device hw:CARD=ROCKCHIPHDMI,DEV=0     ROCKCHIP,HDMI,     Direct hardware device without any conversions plughw:CARD=ROCKCHIPHDMI,DEV=0     ROCKCHIP,HDMI,     Hardware device with all software conversions $ pactl list sinks Sink #0         State: IDLE         Name: alsa_output.platform-es8316-sound.stereo-fallback         Description: Built-in Audio Stereo         Driver: module-alsa-card.c         Sample Specification: s16le 2ch 44100Hz         Channel Map: front-left,front-right         Owner Module: 6         Mute: no         Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB                 balance 0.00         Base Volume: 65536 / 100% / 0.00 dB         Monitor Source: alsa_output.platform-es8316-sound.stereo-fallback.monitor         Latency: 1896804 usec, configured 2000000 usec         Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY         Properties:                 alsa.resolution_bits = "16"                 device.api = "alsa"                 device.class = "sound"                 alsa.class = "generic"                 alsa.subclass = "generic-mix"                 alsa.name = ""                 alsa.id = "ff890000.i2s-ES8316 HiFi ES8316 HiFi-0"                 alsa.subdevice = "0"                 alsa.subdevice_name = "subdevice #0"                 alsa.device = "0"                 alsa.card = "0"                 alsa.card_name = "ROCKCHIP,ES8316"                 alsa.long_card_name = "ROCKCHIP,ES8316"                 device.bus_path = "platform-es8316-sound"                 sysfs.path = "/devices/platform/es8316-sound/sound/card0"                 device.form_factor = "internal"                 device.string = "hw:0"                 device.buffering.buffer_size = "352800"                 device.buffering.fragment_size = "176400"                 device.access_mode = "mmap+timer"                 device.profile.name = "stereo-fallback"                 device.profile.description = "Stereo"                 device.description = "Built-in Audio Stereo"                 module-udev-detect.discovered = "1"                 device.icon_name = "audio-card"         Ports:                 analog-output-headphones: Headphones (priority: 9000)         Active Port: analog-output-headphones         Formats:                 pcm Sink #1         State: IDLE         Name: alsa_output.platform-hdmi-sound.stereo-fallback         Description: Built-in Audio Stereo         Driver: module-alsa-card.c         Sample Specification: s16le 2ch 44100Hz         Channel Map: front-left,front-right         Owner Module: 7         Mute: no         Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB                 balance 0.00         Base Volume: 65536 / 100% / 0.00 dB         Monitor Source: alsa_output.platform-hdmi-sound.stereo-fallback.monitor         Latency: 1949733 usec, configured 2000000 usec         Flags: HARDWARE DECIBEL_VOLUME LATENCY         Properties:                 alsa.resolution_bits = "16"                 device.api = "alsa"                 device.class = "sound"                 alsa.class = "generic"                 alsa.subclass = "generic-mix"                 alsa.name = ""                 alsa.id = "ff8a0000.i2s-i2s-hifi i2s-hifi-0"                 alsa.subdevice = "0"                 alsa.subdevice_name = "subdevice #0"                 alsa.device = "0"                 alsa.card = "2"                 alsa.card_name = "ROCKCHIP,HDMI"                 alsa.long_card_name = "ROCKCHIP,HDMI"                 device.bus_path = "platform-hdmi-sound"                 sysfs.path = "/devices/platform/hdmi-sound/sound/card2"                 device.form_factor = "internal"                 device.string = "hw:2"                 device.buffering.buffer_size = "352800"                 device.buffering.fragment_size = "176400"                 device.access_mode = "mmap+timer"                 device.profile.name = "stereo-fallback"                 device.profile.description = "Stereo"                 device.description = "Built-in Audio Stereo"                 module-udev-detect.discovered = "1"                 device.icon_name = "audio-card"         Ports:                 analog-output: Analog Output (priority: 9900)         Active Port: analog-output         Formats:                 pcm Sink #2         State: IDLE         Name: alsa_output.platform-spdif-sound.stereo-fallback         Description: Built-in Audio Stereo         Driver: module-alsa-card.c         Sample Specification: s16le 2ch 44100Hz         Channel Map: front-left,front-right         Owner Module: 8         Mute: no         Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB                 balance 0.00         Base Volume: 65536 / 100% / 0.00 dB         Monitor Source: alsa_output.platform-spdif-sound.stereo-fallback.monitor         Latency: 1985337 usec, configured 2000000 usec         Flags: HARDWARE DECIBEL_VOLUME LATENCY         Properties:                 alsa.resolution_bits = "16"                 device.api = "alsa"                 device.class = "sound"                 alsa.class = "generic"                 alsa.subclass = "generic-mix"                 alsa.name = ""                 alsa.id = "ff870000.spdif-dit-hifi dit-hifi-0"                 alsa.subdevice = "0"                 alsa.subdevice_name = "subdevice #0"                 alsa.device = "0"                 alsa.card = "1"                 alsa.card_name = "ROCKCHIP,SPDIF"                 alsa.long_card_name = "ROCKCHIP,SPDIF"                 device.bus_path = "platform-spdif-sound"                 sysfs.path = "/devices/platform/spdif-sound/sound/card1"                 device.form_factor = "internal"                 device.string = "hw:1"                 device.buffering.buffer_size = "352800"                 device.buffering.fragment_size = "176400"                 device.access_mode = "mmap+timer"                 device.profile.name = "stereo-fallback"                 device.profile.description = "Stereo"                 device.description = "Built-in Audio Stereo"                 module-udev-detect.discovered = "1"                 device.icon_name = "audio-card"         Ports:                 analog-output: Analog Output (priority: 9900)         Active Port: analog-output         Formats:                 pcm
Of course, all the sounds "es8316" / "hdmi" / "spdif" are working.
However, sadly, "mainline-kernel" has not yet implemented "video-accelerator" (mpp related),
it is not fun even if only the sound comes out.
So, I usually do not use "mainline-kernel".
(10-26-2018, 05:46 AM)t4_4t Wrote: ...
So you mark it as "SOLVED". Could you kindly point us to the solution? Diffs or so... since that comes to modifying kernel source as you've mentioned.
Please make a 'Pull Request' so we all can hear something. Thanks.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(10-26-2018, 05:46 AM)t4_4t Wrote: The problem of "es8316" is quite tough and can not be solved by only modifying "*.dts" or "kernel-config".
"my-kernel"
I understand, i need to modify sound/soc/codecs/es8316.c
Can you tell me which other files i need to modify?
Can you share your asound.rc file?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,758 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 181,975 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,340 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,178 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,270 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,575 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 131,320 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,820 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,282 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,851 01-13-2023, 06:21 PM
Last Post: misterc
