Touchscreen
Hello all,
I am planning to put together an Android device using a ROCKPro64 board. I'm a bit overwhelmed by the amount of interfaces available so I come here for counsel. I would like to use a 10" touchscreen, specifically the one offered on Amazon here. It uses HDMI but if anyone knows of a better solution please chime in! Honestly, I don't even know where to obtain a touch screen with some of the interfaces supported. in any case, I welcome all suggestions.
Thanks!
PBJ
(07-18-2018, 11:50 PM)FancyPBJ Wrote: Hello all,
Thanks!
PBJ
Pine64 currently work on a 10.1" IPS 1280x720 touch screen LCD panel using MiPi interfaceand plan to introduce in a month time.
Thank you for the heads up!
PBJ
Thanks!
PBJ
Just checking in to see what type on progress have you made. Are you any closer to making this available?
PBJ
Thanks!
PBJ
PBJ
Already received prototype and currently under test. Looking forward to release on late September.
Thanks!
PBJ
PBJ
Still anxiously waiting for more info!
+1 subscribing for news.
Would like to know if it's possible to use cheap 10" touch displays from Aliexpress (~$20..40, usually marked with "Huawei MediaPad M3 Lite 10" or other tablets, 1920x1200) with ROCKPro64
  External Touchscreen via DP-Alt Mode soloquintett 0 3,319 05-01-2023, 12:29 PM
Last Post: soloquintett
  USB 15+-inch touchscreen monitors Splinter 0 3,026 09-26-2020, 05:23 AM
Last Post: Splinter
