Lakka poor performance experience
Hi guys,
The performance with Rock64 and Lakka aren't good enough to have a good experience out of the box, I got a better experience with a PI2 and Retropie.
Probably Lakka needs a better tuning so I would like to understand where is the place to get help to solve these issues, I mean here or on the Libretro forum.
Thanks in advance,
Daniel
Thats probably because there are no working SDL drivers. I've spoken to RecalBox devs recently and they are working on an implementation for RK SOCs. TL has kindly agreed to send them dev kits and they promised support for the R64.
As a side note, I have a dev build of Lakka with somewhat improved performance. Regardless, 2D emulators already run better than on RPI3.
PS1 works really well too. For N64 and other 3D emulators ... you'll probably want the RockPro64.
Have you tried Retroarch in Android ?
Thanks for your reply.
Eventually playing with the setup I was able to have some improvements, N64 emu plays now decently. And now I am dealing with the PS1 emulation.
There are some missing piece in this Lakka version like the overlay assets so I had to download them manually. Withh the overlay enabled I could tricks the graphics and keep the frame rates high.
I look forward to see the rockpro64 however Hard Kernel, the one of the Odroid boards, is preparing a better board with the same arm chipset.
Even if the specs of this latter are better I believe that Odroid-XU4 might continue to be better for the emulation because the higher numbers of cores.
Sad Bad first experience with rock64. Performs worse than my pi :( ekg 9 19,482 05-24-2019, 09:42 AM
Last Post: thatchunkylad1989
  Better performance larj 10 20,046 03-21-2019, 09:13 PM
Last Post: onfire4g05
  Another bad experience with Rock64 nightfly64 1 4,551 01-30-2019, 09:29 AM
Last Post: va88
  Video playback performance va88 0 3,592 12-19-2018, 01:19 PM
Last Post: va88
  Performance and stability issues Openmediavault jgpacc 10 23,975 11-02-2018, 01:46 PM
Last Post: jgpacc
  Rock64 performance: eMMC / SD Card / USB3 (SSD/HDD) Blastmun 15 41,822 08-16-2017, 08:44 AM
Last Post: stuartiannaylor
  Performance question - Rock64 vs A64+ vs RPi 3 jl_678 21 53,807 07-29-2017, 03:06 PM
Last Post: jl_678
