Mate Kiosk Problem on Rock64
Brick
Hi gang.  I have the strangest problem and figured I'd see if any of you have experienced it.  I'm using the latest xenial mate image on a high quality sd card with plenty of power.
For those of you who don't know this, chromium browser can be run with a -kiosk flag that fullscreens it and takes away the location bar. You can still close it with altf4, but otherwise you'd never know it's a browser.
On this Rock64 image, right "out of the box", when you put it into kiosk mode and autolaunch, when it boots, it's hidden, and there is a tab of it down in the tray.  It's there, technically. You can grab it sometimes and move it, without being able to see it, and the computer is locked until you hit altf4 and close chromium.
And get this, on two occasions, it didn't happen and it booted into chromium fine.
It's like it can't render it, and this is the 4g model of the rock64.
Debian mate doesn't do it.
Hi again. I still haven't found an answer to this problem. There is a similar thread on github and it didn't really go anywhere.
https://github.com/ayufan-rock64/linux-build/issues/52
Anyone have any ideas?
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 2,754 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 89,910 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,595 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,475 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,554 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,537 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,514 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,696 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 29,708 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,606 09-20-2024, 11:18 AM
Last Post: AwU2HBg
