USB -> eMMC adapter coming soon
You can expect to see those adapters in the shop in the near future. Here are some pictures tllim linked earlier in the IRC.
https://imgur.com/UhMult0
https://imgur.com/GU7GIqz
https://imgur.com/xq7VGki
That's awesome Luke. Should make the eMMC flashing much easier.
Great work ! Big Grin
I was looking for one, because I have the f**d emmc sandisk 64gb that doesn't run. ;(
This will be great to see if it's a hardware problem or a software problem...
(10-11-2017, 06:29 AM)erchache2000 Wrote: I was looking for one, because I have the f**d emmc sandisk 64gb that doesn't run. ;(
Check IRC logs - software.
Yep, I received a email support that says sandisk isn't compatible with pinebook yet.
A new patch will come on next two weeks Tongue
I've got one of those adaptors.
Looks cheap but works as designed.
Usage is simple as hell.
Just flash OS image as you would do to SDcard.
No need for SD 2 MMC images Big Grin
As new Rock64 user I can definitely recommend this simple solution.
I have a couple now too and they seem easy enough too use. Only things I would recommend is to handle them carefully since open electronics/connectors are ESD sensitive and the board-to-board connectors of the eMMC modules are not designed for hundreds of mating cycles like cable connectors...
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,655 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 6,946 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,232 08-19-2021, 06:46 PM
Last Post: bcnaz
  USB3 to Ethernet adapter giuseppe 0 3,232 11-11-2020, 05:48 PM
Last Post: giuseppe
  Receiving errors about eMMC (?) acasta 11 27,228 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 48,791 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 177,489 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 3,852 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 6,289 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 15,176 05-06-2018, 05:41 PM
Last Post: pfeerick
