Can I run Alpine Linux on Pine64?
Alpine Linux has aarch64 on Downloads section:
https://alpinelinux.org/downloads/
Anyone using? (It is possible to use?)
(07-26-2017, 12:17 AM)douglasmiranda Wrote: Alpine Linux has aarch64 on Downloads section:
No and yes;
... if you use the spl uboot dts and so forth for the pine64+ (or the rock64) and then copy over the /rootfs from Alpine , you might be able to make it work;  fire219 was able to make fedora work this way;
Having said that, typically the gnu+linux needs to be built specifically for the hardware it will be running on; because every SoC is different--  a different processor.
Thanks, I'll try xD
No and yes;
Many SoCs can use mainline kernel + appropriate devicetree file to boot, but most SoCs don't get good mainline support
  Programming languages support under PINE64 baryluk 6 20,650 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,513 03-28-2020, 06:20 PM
Last Post: ty1911
  Manjaro arm on pine64+ roel 2 10,643 10-19-2019, 05:13 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 96,439 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,355 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,779 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Volumio for PINE64 Released mikelangeloz 11 39,130 03-22-2019, 09:25 AM
Last Post: llungster
  Gentoo Linux test image xalius 23 73,170 01-28-2019, 11:05 PM
Last Post: necrose99
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,653 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,102 01-04-2019, 03:47 PM
Last Post: Max11
