06-01-2016, 11:16 AM
(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
(06-01-2016, 11:16 AM)jdt Wrote: @benpope81 - I was probably a bit defensive. Sorry about that. Moar coffee.No worries, internet, etc.
06-01-2016, 11:26 AM
I just enabled iSCSI as module (see https://github.com/longsleep/linux-pine6...930310e560) - will be in the next release.
06-01-2016, 11:34 AM
Awesome - thanks. I was just tracking that down and saw the "updated 1 minute ago".
Also hoping to get openvswitch working: ubuntu@pine64:~$ sudo ovs-vsctl add-br internal ovs-vsctl: Error detected while setting up 'internal'. See ovs-vswitchd log for details. ubuntu@pine64:~$ cat /var/log/openvswitch/ovs-vswitchd.log . . . 2016-06-01T17:30:33.307Z|00005|bridge|INFO|ovs-vswitchd (Open vSwitch) 2.5.0 2016-06-01T17:31:23.407Z|00006|memory|INFO|5848 kB peak resident set size after 50.1 seconds 2016-06-01T17:31:27.141Z|00007|dpif_netlink|ERR|Generic Netlink family 'ovs_datapath' does not exist. The Open vSwitch kernel module is probably not loaded. . . . ubuntu@pine64:~$ modprobe ovs_datapath modprobe: FATAL: Module ovs_datapath not found in directory /lib/modules/3.10.101-4-pine64-longsleep ubuntu@pine64:~$
06-01-2016, 11:36 AM
(06-01-2016, 11:26 AM)longsleep Wrote: I just enabled iSCSI as module (see https://github.com/longsleep/linux-pine6...930310e560) - will be in the next release.You know you rock. @tllim, why doesn't tapatalk allow me "+1". I mean seriously, delegate, dude. How is everybodies problem, yours? This is my problem; I want "like", "+1", whatever. Fix it now or I'll sue you for something I haven't yet decided upon but my lawyers will find.
06-01-2016, 12:18 PM
Fingers crossed that this is the right module configuration flag and location to enable openvswitch: https://github.com/longsleep/linux-pine64/pull/20
Yeah almost. The configuration is created with the savedefconfig target and thus has specific sorting. Anyhow, i enabled that module as well and will include it with the next release.
06-02-2016, 11:05 PM
I've installed this build, resized the filesystem, updated, upgraded, and installed the desktop (all through the serial console) but I can't get any HDMI output. Have tried 3 different monitors, 2 of which were 1920 monitors, tried 2 different HDMI cables, nothing.
The monitors obviously know something is there, it's just a black screen. In the boot log I get this message, which is worrying: [FAILED] Failed to start Load Kernel Modules Could this be my issue? Also failed to set console keymap, but that doesn't sound nearly as serious. Pine64 1GB with a 64GB class 10 Sandisk SD card (which obviously is good because Ubuntu is running fine). U-Boot 2014.07-4-pine64-longsleep Ubuntu 16.04 LTS (GNU/Linux 3.10.65-7-pine64-longsleep aarch64) Any tips much appreciated...
06-04-2016, 07:15 PM
Longsleep,
I prefer this minimalist approach. It keeps the quick installation process less cluttered and more educational. Stay command line or add the desktop of your choice. I used to do the roughly same with Unix builds on older hardware. Deja vu! (-: Also, the contents of /usr/local/sbin were very thought out and very helpful. Thank you. |
Users browsing this thread: 11 Guest(s)
