RTC Battery Module
Hey guys.
My question regarding RTC is:
For normal use of Pine64, lets say RemixOS, Linux (in future), Kodi, etc. Is the RTC a requirement or a must have?
Speaking as someone that uses various similar types of board RTC is more of a want feature than a requirement.
Once the internet is up and running getting accurate time is a mere NTP call away.
And note, the Raspberry Pi does not have a real time clock, unless you had an i2c real time clock.
If you are going to be running your pine64 stand-alone with no networking, and no GPS unit, you might want to buy the battery connection to keep the time accurate. Note, the Pine64 has a real time clock inside of it, what the add-on part provides is a connection so that you can use a coin style battery to keep the RTC powered when the main unit is not powered. A non-rechargeable coin cell should last several years.
Rainbow Lithium battery temperature readout? GregH 0 3,237 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 107,750 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 6,738 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 9,086 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 46,977 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 6,203 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 87,366 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 15,635 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 3,846 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 3,756 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
