49 minutes ago
I've been using my PinePhone and a Pinebook as daily drivers for a while, and I want to build a small utility app for my own use without getting deep into a full SDK setup. There seem to be a lot of AI app builders floating around, and honestly I'm not sure where to start.
My main concern is whether anything generated by these tools can actually run or be tested on ARM devices like ours, or if I'd be stuck building on my work laptop and just hoping the output works. I also don't want to commit to a subscription before knowing that the code export isn't locked down to one platform. I'd rather build something minimal and own the code.
Has anyone here used a no-code app builder for a PinePhone-compatible tool and actually gotten it to run? Which ones export clean code that works on ARM, and which ones should I avoid? Any input from people who've tried this would help.
