http://pinenote.mweigand.net/repo_pn_stable Public Key is not available
Hello, I just ran`sudo apt update`via ssh on my V2 PineNote and I'm receiving the following warning
Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://pinenote.mweigand.net/repo_pn_stable trixie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E0B6906147A709C6
(01-04-2026, 10:47 AM)nailliK Wrote: Hello, I just ran`sudo apt update`via ssh on my V2 PineNote and I'm receiving the following warning
Hi there!
I encountered the same issue, I was able to fix it by running the commands below:
sudo curl -L --output-dir /etc/apt/sources.list.d -O https://github.com/PNDeb/pinenote-tweaks/raw/refs/heads/main/pn_custom_repo_and_keyring/apt_sources/pnedeb.sources sudo curl -L --output-dir /usr/share/keyrings -O https://github.com/PNDeb/pinenote-tweaks/raw/refs/heads/main/pn_custom_repo_and_keyring/keyrings/pinenote_repo_key_5.gpg
Big Grin Quill OS for the PineNote Szybet 4 3,310 08-02-2026, 10:32 AM
Last Post: tux-linux
  does the Joplin note taking app work on the PineNote? derdon 5 6,653 10-15-2025, 06:17 AM
Last Post: mamta25
  New PineNote: No WiFi after wakeup from suspend j_s 5 5,243 08-12-2025, 01:09 PM
Last Post: krexplex
  Page turner for PineNote (Airturn, Joyo JSP-01) - for sheet music (using KOReader) macmartin 0 2,962 05-09-2025, 09:10 AM
Last Post: macmartin
  WiFi works or not after wakeup post October 2024 PineNote j_s 1 2,675 12-30-2024, 01:12 AM
Last Post: franzthiemann
Question How to write handwriting note app that not delay in android app for PineNote? wannaphong 0 4,574 10-30-2022, 07:29 AM
Last Post: wannaphong
Photo First sketches for a PineNote UI 1jss 6 13,187 10-13-2021, 10:24 AM
Last Post: 1jss
