Does WiFi work on your 2nd batch PineNote after wake from sleep?
Worked out of box, continues to work after updates
50.00%
1
Worked out of box, stopped working after updates
0%
0
Does not work now, do not know about out of box
0%
0
Did not work out of box, works after update
0%
0
Never worked
50.00%
1
2 vote(s)
WiFi works or not after wakeup post October 2024 PineNote
This poll is to determine how widespread the "No WiFi after resume" problem is among second batch PineNotes is. Also vote if you flashed the pinenote-debian-image to a first batch PineNote, but please say to in a post to this thread.
Symptoms are no WifI icon in the status bar, no WiFi button in the config menu (pop up by tapping upper left screen corner), and no wlan0 device in output from ip addr command.
I have this issue occasionally after waking from sleep, like one in ten times
Big Grin Quill OS for the PineNote Szybet 4 3,547 08-02-2026, 10:32 AM
Last Post: tux-linux
  http://pinenote.mweigand.net/repo_pn_stable Public Key is not available nailliK 1 2,505 02-23-2026, 05:58 PM
Last Post: HippopoStar
  does the Joplin note taking app work on the PineNote? derdon 5 6,876 10-15-2025, 06:17 AM
Last Post: mamta25
  Wifi 5Ghz Issue nicolaos 0 9,115 09-17-2025, 06:36 PM
Last Post: nicolaos
  New PineNote: No WiFi after wakeup from suspend j_s 5 5,437 08-12-2025, 01:09 PM
Last Post: krexplex
  Page turner for PineNote (Airturn, Joyo JSP-01) - for sheet music (using KOReader) macmartin 0 3,061 05-09-2025, 09:10 AM
Last Post: macmartin
Question How to write handwriting note app that not delay in android app for PineNote? wannaphong 0 4,656 10-30-2022, 07:29 AM
Last Post: wannaphong
Photo First sketches for a PineNote UI 1jss 6 13,265 10-13-2021, 10:24 AM
Last Post: 1jss
