Pinetab-V boot rescue
I managed to bugger up the boot configuration of my pinetab-V. At first, only a blank screen would come up, and it wouldn't even boot into the sdcard, but this much is fixed.
Now, I want it to boot from the EMMC, which it doesn't do. Luo provides an u-boot update script in the GitHub releases for updating the bootloader, but I do not believe this tool is suited from rescuing the boot of a broken system.
I will review the starfive documentation on booting, but if someone has experienced a similar issue, assistance would be appreciated. I have some critical projects going on I must dedicate my entire attention to, and cannot afford to tinker as I usually do.
I think I got it, but haven't tested it out yet. The "spl_tool" claims to fix the emmc boot issue if used along with an installation img. It should resolve the problem, but highly likely to overwrite all the work performed to personalize the system. Everything is currently being backed up to salvage as much as possible, and it should take me 56 minutes to download the installation image on my ad-hoc wifi connection.
So, we will see.
Well, that was not the correct answer, because
Quote:spl_tool is a signature tool used to generate spl header information and generate u-boot-spl.bin.normal.out.
spl_tool can also fix the issue of emmc booting.
The spl_tool is compiled for x86_64, and not Risc-V. So, I imagine it is used for generating XYZ for imgs before they are installed, and not for rescuing a broken boot after installed.
The solution was much more basic than first assumed. Syslinux was misconfigured. I documented the process of how to repair the boot on my blog for future reference.
  PineTab-V Experiences segaloco 0 401 09-29-2026, 11:28 PM
Last Post: segaloco
  Won't boot with a MicroSD inserted acruhl 0 1,466 08-07-2025, 06:59 PM
Last Post: acruhl
  Any updates on Bluetooth for PineTab 2? BluetoothBroke 1 2,426 08-05-2025, 06:38 AM
  Bricked Pinetab 2 vatin 6 5,547 06-06-2025, 08:46 AM
Last Post: maxaltepo
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 4 7,310 05-31-2025, 02:34 PM
Last Post: stevepaesani
  Possible solution to boot and/or eMMC failures sanctimonious_spoon 0 2,724 04-01-2025, 11:01 PM
Last Post: sanctimonious_spoon
  Gentoo on Pinetab istewart 0 2,205 01-26-2025, 08:21 PM
Last Post: istewart
  Pinetab-V Upgrade WrVLink 0 2,359 12-14-2024, 02:30 AM
Last Post: WrVLink
  PineTab Bluetooth PimpDiCaprio 5 6,721 11-02-2024, 11:46 AM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 23,525 02-28-2024, 05:03 AM
Last Post: Surehand53
