Gentoo on Pinetab
I've been trying to set up Gentoo on an SD card in my Pinetab2 since I received it a few weeks ago. I am generally more comfortable with Portage than pacman, and I would also like to test and possibly provide support for Gentoo's arm64 binary packages. This means that I have built a partition table up from scratch on the SD card, rather than duplicating an existing installation image. It's a very simple partition table:
mmcblk1p1: EFI boot partition mounted at /efi, FAT32
mmcblk1p2: swap
mmcblk1p3: root partition, ext4
The Pine64 RockPro64 entry on the Gentoo wiki: https://wiki.gentoo.org/wiki/PINE64_ROCK...bootloader indicates that whoever wrote it had success using a standalone build of Grub on an EFI system partition to get the RockPro to boot, but I am not having the same success on the Pinetab. Should I instead be installing U-Boot to the boot partition? Or flashing it to the first sectors of the SD card? I am still unsure about the normal procedure for using U-Boot or where it should be installed.
At what point might I also want to consider the rk2aw bootloader? This person had success using it with Fedora: https://www.jistr.com/blog/2023-11-27-fe...-pinetab2/
It also seems like the tablet is now not booting at all with the SD card inserted, which was not the case before I formatted the SD card with the boot partition. But it could be possible that it is actually attempting to boot but I just have no video output/keyboard backlight, since the stock Gentoo binary kernel probably doesn't have drivers for these. I can attempt to use the Danctnix kernel patches and build my own kernel, but I am curious, exactly what devices does it patch in support for?
The bes2600 wifi driver is not important to start with, as I have a USB-Ethernet adapter that has Linux kernel support. I plan to install the wifi driver after I have a properly booting system, and also write a Gentoo ebuild for it.
  PineTab-V Experiences segaloco 0 401 09-29-2026, 11:28 PM
Last Post: segaloco
  Pinetab-V boot rescue anoduck 2 1,870 10-21-2025, 12:58 AM
Last Post: anoduck
  Any updates on Bluetooth for PineTab 2? BluetoothBroke 1 2,426 08-05-2025, 06:38 AM
  Bricked Pinetab 2 vatin 6 5,548 06-06-2025, 08:46 AM
Last Post: maxaltepo
  Pinetab-V Upgrade WrVLink 0 2,361 12-14-2024, 02:30 AM
Last Post: WrVLink
  PineTab Bluetooth PimpDiCaprio 5 6,721 11-02-2024, 11:46 AM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 23,539 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 2,965 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 10,820 09-01-2023, 01:13 PM
Last Post: acruhl
  PineTab 2 Dead Screen Kramey 16 18,539 08-12-2023, 05:44 PM
Last Post: Kramey
