Possible solution to boot and/or eMMC failures
After attempting to flash an image to the eMMC, my Pinetab 2 would not boot from the eMMC, and when I booted from the SD card, I saw an error similar to the following
mmc0: error -110 whilst initialising MMC card
I tried flashing the eMMC with the factory image multiple times, but none of the attempts succeeded.
Based on my experience with Xilinx SoCs, I suspected an issue with the SD Host Controller (SDHC). I poked at some of the internal registers on the SDHC in U-Boot, but while I noticed some possible patterns, I couldn't pinpoint a definitive issue or find any magical reset sequence that fixed the issue. I was able to observe that some of the low-level SD commands were timing out due to lack of response. Off a hunch, I removed the back cover and disconnected the battery cable form the main board (I also disconnected the other connectors so I could examine the main board, but given that both the SDHC and the eMMC are located on the main board, I wouldn't expect the removal of any of these to have an impact). When I reinserted the cable and booted the Pinetab 2 I was able to write an image to the eMMC and subsequently boot from the eMMC. My theory is that the SD/MMC/eMMC state machine in the SDHC was somehow corrupted, leaving it unable to enter a state where it could respond to commands; I suspect that fully de-energizing and re-energizing the circuit caused it to go into reset, getting it back on an operational path. It's possible the issue is with the eMMC chip instead of the SDHC, but my knowledge of SD/MMC standards and implementation is limited and I was unable to find substantial documentation on the eMMC chip. As a caveat, I have not had the time to attempt to reproduce the issue or my solution, so it's possible my observation and solution were subject to confounding factors I didn't test for. (Time aside, I damaged the microSD card reader while attempting to reseat the back cover, so I would need to get USB booting to work in order to be able to effectively run tests.)
Hopefully, this is helpful to someone.
  Voidlinux working on eMMC cheepeero 1 2,411 04-01-2026, 04:14 PM
  Pinetab-V boot rescue anoduck 2 1,821 10-21-2025, 12:58 AM
Last Post: anoduck
  Won't boot with a MicroSD inserted acruhl 0 1,447 08-07-2025, 06:59 PM
Last Post: acruhl
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 4 7,253 05-31-2025, 02:34 PM
Last Post: stevepaesani
  failure to boot ajhiii070 0 2,285 07-07-2023, 01:19 PM
Last Post: ajhiii070
  Emmc information ask Fanche35 2 4,025 07-07-2023, 08:48 AM
  PineTab2: How to fix "Package corrupted" error on update [SOLUTION] IPXFong 0 2,329 06-21-2023, 05:52 PM
Last Post: IPXFong
  Unable to boot off SD card gdsmit1 5 11,359 12-30-2020, 03:24 PM
Last Post: gdsmit1
