Has anyone successfully upgraded the PineBook Pro’s SSD? Any recommended brands/models?
04-23-2025, 11:31 AM
Should be in Pinebook Pro Hardware and Accessories subforum.
The PBP ships with an eMMC installed, not an SSD. The HardKernel 256GB eMMC is the largest pluggable emmc with a PBP-compatible socket that I know about. I made a thread on it: Hardkernel 256GB eMMC with lvm2 on PBP It's still working, hasn't come loose yet. If you're going to be using the NVME adapter with an actual SSD, there is a long compatibility table on the wiki: https://wiki.pine64.org/wiki/Pinebook_Pr...SSD_drives (04-23-2025, 11:31 AM)Dendrocalamus64 Wrote: Should be in Pinebook Pro Hardware and Accessories subforum. oh i found the method useful, i thank you so much for sharing! |
| Possibility to have other CPU brands | zxorg | 2 | 3,793 |
11-21-2022, 06:19 PM Last Post: KC9UDX |
