Any recommended brands/models?
Has anyone successfully upgraded the PineBook Pro’s SSD? Any recommended brands/models?
Should be in Pinebook Pro Hardware and Accessories subforum.
The PBP ships with an eMMC installed, not an SSD.
The HardKernel 256GB eMMC is the largest pluggable emmc with a PBP-compatible socket that I know about.
I made a thread on it:
Hardkernel 256GB eMMC with lvm2 on PBP
It's still working, hasn't come loose yet.
If you're going to be using the NVME adapter with an actual SSD, there is a long compatibility table on the wiki:
https://wiki.pine64.org/wiki/Pinebook_Pr...SSD_drives
(04-23-2025, 11:31 AM)Dendrocalamus64 Wrote: Should be in Pinebook Pro Hardware and Accessories subforum.
Hardkernel 256GB eMMC with lvm2 on PBP fnf
oh i found the method useful, i thank you so much for sharing!
  Possibility to have other CPU brands zxorg 2 3,794 11-21-2022, 06:19 PM
