Rhino Linux
I tried to test the new Rhino Linux version 2025.1 on my pinetab via SD-card. When launched, the pinetab shows the "Rhino"-splashscreen for some seconds, but then turns dark. Has anybody successfully installed it?
You have to update a second time, before you reboot. After the first update, WLAN and USB-LAN do not work anymore, thus you are blocked from any further update. But if you repeat the update command a second time before booting, anything will be ok.
  Reinstallation Arch Linux ARM from scratch victor_yeh 2 2,339 03-08-2026, 03:39 PM
Last Post: janqbtzki
  beta release of a Linux mobile app strength training app coryholl 1 11,001 08-29-2025, 06:02 PM
Last Post: coryholl
  Danctnix Linux still maintained? Corkonian 9 10,847 09-17-2024, 12:54 PM
Last Post: zetabeta
  Wrong Linux partitions on image - no Linux Rules. Piotr Bujakowski 0 2,312 08-18-2024, 12:54 PM
Last Post: Piotr Bujakowski
Star PINETAB – 10.1″ Linux Tablet With Detached Backlit Keyboard (EARLY ADOPTER EDITION) f ullbeking 1 5,870 03-27-2021, 10:32 AM
Last Post: JMoore
  how do I know which linux OS I can install on a pinetab dln949 20 39,875 09-11-2020, 05:07 AM
