I Got A Bit Too Flash Happy (Help)
I wasn't paying attention and accidentally installed Factory SailfishOS and overwrote the Tow Boot, I attempted to finish the installation and click the two prompts after clicking "whatever" part 1 and where it asked if I wanted to encrypt phone which I chose no then told me to Reboot after it was done processing.
Now all it does when I power on is the green led just flickers a few times and that's it.
But when what I want to do is install Ubuntu Touch.
Do I need Tow Boot or uBoot
Are you sure you have a PinePhonePro?
If you have a PinePhonePro, tow boot should be on the SPI.
I managed to fix it.
Yes but the factory image for SailfishOS wipes out TowBoot and installs uBoot:
Sailfish with RK2AW ppp-factory-image-20231118.img.gz is the one that installed uBoot on me
I grabbed a TowBoot image off the GitHub extracted it then burned the installer image with BelenaEtcher
I discovered though no Ubuntu touch has a working camera though so I'm back on Mobian
(11-05-2024, 01:40 PM)dorkydev Wrote: I managed to fix it.
Tiny Fishing
Congratulations on fixing it, I will save the way you did it so that when necessary I can use it right away without having to search for it.
(11-05-2024, 08:20 AM)mikehenson Wrote: Are you sure you have a PinePhonePro?
Not anymore, at least not as shipped. The PinePhone Pro now ships with rk2aw on the SPI. You can overwrite it with Tow-Boot if you wish, but it does not ship that way anymore.
  Flash Pinephone Pro image from SD card to eMMC? jcun4128 9 15,171 03-11-2022, 09:09 AM
Last Post: fxc
  Noob here. Unclear how to flash different distros icantremember 3 5,537 02-02-2022, 11:09 PM
Last Post: bcnaz
  PSA: Do _not_ flash OG PinePhone OS images to the PinePhonePro Ulfnic 1 3,079 01-27-2022, 09:29 PM
Last Post: bcnaz
