Wifi not recognized - Pine64+ / Debian Bullseye
I have a Pine64+ single board computer, with the wifi/bt POT accessory.
Have successfully installed Debian 11 ( Bullseye ) and have that running, but cannot for the life of me seem to get the wifi/bt module enabled.
I have installed the firmware-realtek package, which should have the right firmware bits, but something else appears to be missing, and I'm at a loss.
cparker@pine64:~$ uname -a Linux pine64 5.10.0-32-arm64 #1 SMP Debian 5.10.223-1 (2024-08-10) aarch64 GNU/Linux cparker@pine64:~$ cat /etc/os-release PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye
The Realtek FW .bin files are in /usr/lib/firmware/rtlwifi  for the rtl8723bs.
Modprobe doesn't appear to do anything.
Is it an issue with Debian / Bullseye?  Would Bookworm be different, or Armbian?  Not stuck with this version, but it's the first one I was able to get to boot properly, with everything else working.
  Armbian for Pine64 LTS Mark88 1 3,223 07-26-2024, 12:48 PM
Last Post: Nepse
  Kernel rebuild resources and process for pine64-LTS Atreyo tech 2 7,594 07-02-2021, 12:23 AM
Last Post: Atreyo tech
  Networking on A64 LTS broken on Debian with Kernel 5.9 kuleszdl 0 5,148 01-02-2021, 06:26 PM
Last Post: kuleszdl
  No HDMI output on standard Debian install / no boot sagada 2 8,145 09-06-2020, 03:54 AM
Last Post: kuleszdl
  Building OP-TEE OS for pine64-LTS foreverska 1 6,322 12-13-2019, 03:32 PM
Last Post: foreverska
  Debian dead on A64-LTS? s0ke 4 12,387 01-06-2019, 05:46 PM
Last Post: digs
  SoPine/Pine64 LTS: Ubuntu Mate is not booting jaganteki 0 4,294 11-20-2018, 10:49 PM
Last Post: jaganteki
  Problem setting Pine64 as a USB device martin357 2 7,148 07-02-2018, 02:08 AM
Last Post: martin357
