PinePhone Dock with laptop?
Wondering if anyone can help out. I have a Pinephone and an older version of the dock, however, I am in a remote location and need an ethernet port on my laptop. When plugging in the Pinedock into my laptop, the USB ports seem to work fine, but there is no power on the Ethernet port. Is there any way to make the dock worth on a laptop with Windows 10?
Thanks in advance for the help.
Can you try booting a GNU/Linux live image on your laptop? Any distro will do, really. Just put the live image onto an empty (or emptiable, i.e., with no important data on it) USB stick and boot it. If the distro recognizes the Ethernet port, you will know that it is a driver issue and that you need to find a Windows driver for the device if you want it to work under Windows. If it also does not work in GNU/Linux, then it is likely a hardware incompatibility.
(12-03-2023, 10:15 PM)Kevin Kofler Wrote: Can you try booting a GNU/Linux live image on your laptop? Any distro will do, really. Just put the live image onto an empty (or emptiable, i.e., with no important data on it) USB stick and boot it. If the distro recognizes the Ethernet port, you will know that it is a driver issue and that you need to find a Windows driver for the device if you want it to work under Windows. If it also does not work in GNU/Linux, then it is likely a hardware incompatibility.
Good idea... I have a Linux distro here somewhere on a separate SSD... Thanks for the suggestion. No luck on a Windows driver... but that would be awesome if I could find one.
  Replacement battery for PinePhone? j_s 9 1,198 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 2,040 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 9,445 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 2,065 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 1,947 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 779 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 1,717 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 6,161 06-26-2024, 07:11 AM
Last Post: dachalife
  Case for Pinephone totilele 13 13,273 04-11-2024, 11:48 AM
Last Post: gramonyl
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 11,684 10-22-2023, 08:43 PM
