Using Signal on PinePhone in mid-2023?
#31
(06-23-2023, 07:39 AM)dante404 Wrote:
(06-21-2023, 09:32 AM)Pelecanus Wrote: Maybe a workaround is to use the signal-cli?:
Yes, would be an option - Better than nothing I guess Wink - Thank you!
(Used signal-cli just on my Linux-Desktop-PC to activate the Client on the PinePhone, so I guess I will have to get it on the PinePhone as well...)
Did you try to receive the pictures on your Desktop PC? Did that work? If it doesn't work either the problem is something else, not Signal on your PinePhone.
(06-23-2023, 09:47 AM)shulamy Wrote: i have to check it - next week
ezik
Thank you! Smile
(06-23-2023, 12:33 PM)Pelecanus Wrote: Did you try to receive the pictures on your Desktop PC? Did that work? If it doesn't work either the problem is something else, not Signal on your PinePhone.
Yes, in the Signal-Desktop-App on my Linux-Desktop-PC (Kubuntu) it works, I see sent images there. Hmmm... Huh
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
@zetabeta & @shulamy:
Because it seems not to be a general problem according to Pelecanus - Does your "Signal-Desktop-App on PinePhone" show images someone sent you? Huh
i use x86-64 laptop (with debian/linux) for both signal-cli and signal-desktop-app. both work fine. getAttachment also works, and files are stored locally, assuming command receive has been done.
maybe i test signal-desktop-app in a pinephone, but not immediately.
edit: adding debian/linux laptop
edit: typo
(06-23-2023, 08:12 PM)zetabeta Wrote: i use x86-64 laptop for both signal-cli and signal-desktop-app. both work fine. getAttachment also works, and files are stored locally, assuming command receive has been done.
maybe i test siganl-desktop-app in a pinephone, but not immediately.
Ah, my fault sorry, I got you wrong somehow then. Smile
@picture problem: I also can't sent pictures on my PinePhone (takes forever, nothing happens). Really strange. On PC all is still good, recieving, sending... It's like some other package/framework/... used by Signal is missing on my PinePhone/Mobian, but I don't know what it is.
@dante404 Did you see this issue?: Since 6.19.0 I am not able to handle images and attached files
It seems other people have the same problem with Signal Desktop on ARM. Unfortunately no solution so far.
Edit: there is also some discussion in the Mobian matrix room.
you are right. signal-desktop 6.20.0 gave me blurred picture (in mobian)
i will try to finish signal-fli install and check if it is better
ezik
@Pelecanus & @shulamy :
Ah, thank you very much for the infos! Smile
At least I can stop searching for a problem at my specific install/system now. Wink
Hopefully there will be a solution.
Problem persists in version 6.25.0. No attachments download. No avatars download.
Problem persists in version 6.27. All attachments are downloaded and not rendered. Can not send attachments.
(08-11-2023, 02:21 PM)dragonhospital Wrote: Problem persists in version 6.27.  All attachments are downloaded and not rendered.  Can not send attachments.
it seems that you use desktop app? do you use arm64 or x86-64 version?
i use x86_64 version and desktop app with 6.28.0 version and attachments and images work fine.
  Alternatives to Signal or simple signal setup methods? JamesBond009 3 654 04-25-2024, 02:22 PM
Last Post: TRS-80
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,254 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,020 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 484 02-23-2024, 07:27 AM
Last Post: Touchwood
  Sms apps and signal messenger boggle 8 7,430 02-16-2024, 06:03 AM
Last Post: zetabeta
  Slack on PinePhone Adam Seline 5 5,442 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,572 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,025 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 102,621 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,002 11-04-2023, 07:23 PM
