Pinebook no longer boots
What image are you writing to your SD to boot?
Easiest way to figure out if it's the Pro or not is whether it's black or white. Pinebook (OG) is white shell, PBPro is black.
IIRC the OG Pinebook did prioritize SD booting over eMMC, unlike the PBP's rk3399
(04-13-2023, 07:50 AM)tophneal Wrote: What image are you writing to your SD to boot?
I have the OG PineBook in the white shell and was purchased in 2017.
  • CPU: 1.2GHz 64-Bit Quad-Core ARM Cortex A53
  • RAM: 2 GB LPDDR3 RAM Memory
  • Flash: 16 GB eMMC 5.0
  • Wireless: WiFi 802.11bgn + Bluetooth 4.0
  • Display: 14" TN LCD (1366 x 768)
The image I am trying to use is Armbian_23.02.2_Pine64_jammy_current_5.15.93_xfce_desktop.img
And my follow up from last night of trying multiple SD cards, I still the same issue of blank/black screen and no indication of the laptop powering up. I double checked the SD cards with CrystalDiskInfo and it reports the card as 100% healthy.
Moving thread to the OG Pinebook forum.
It sounds like removing your eMMC to at least verify SD boot may be a good idea. It would also allow you to reflash your eMMC or chroot in to repair it, if you have an eMMC to USB adapter (totally worth the ~$15.)
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 3 12,205 11-28-2025, 07:38 AM
  DietPi OS for Pinebook MichaIng 3 13,552 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 91,431 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 4,463 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 3,378 07-10-2023, 07:44 AM
  Stock Debian on original Pinebook moonwalkers 1 7,074 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 8,953 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 9,707 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 7,355 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 5,392 12-25-2020, 04:40 PM
Last Post: ford442
