Mobian USB transfer
How can I transfer a file to my PinePhone Pro running Mobian over USB?
I am reading this article which tells me to download and install some wifi drivers. It says if I have lost network (which I appear to have) then download the files on a computer and transfer them to the PPP over USB. But that doesn't appear to be possible.
You can use a USB stick to transfer the file, or a microSD card, or (assuming you have Tow-Boot installed on the SPI, which is the factory default for PinePhone Pro phones ordered after July 2022 and can be done manually for older ones, but I believe Mobian requires that anyway, does it not?) you can reboot the phone into Tow-Boot USB Mass Storage mode by holding the volume up button at startup before and during the second vibration, then connect your phone to the computer via USB and mount the eMMC partitions on the computer like a USB stick, allowing you to just copy the file to the partition.
Thanks, the mass storage mode worked.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,843 2 hours ago
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 467 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 886 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 500 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 708 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 601 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,404 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,170 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 804 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,079 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
