No calls on Pine Phone Beta convergence edition
I have seen a similar thread below but I think this is a different problem and I would like some advice on how to further investigate this.
I can not make phone calls with this new PinePhone Beta convergence (3GB RAM). The phone establishes a 3G connection and I am able to send and receive text messages. Outgoing calls end immediately, incoming calls go to the voicemail at the network provider.
What I have tried:
1) 2 different SIM cards (both work fine on FP2 with UT and on an android phone)
2) 3 different distros, latest releases of Manjaro (Phosh), Mobian (Phosh) and PostmarketOS (Phosh) in combination wit both SIM cards. Presently Mobian with Kernel 6.1
3) I have run the Beta Edition factory test OS build from SD card and the modem Debugger shows no abnormalities (see attachment)
4) I tried to set network manually at 3G as in suggested in the previous thread.
5) Things work on my original PinePhone (UB Ports CE) .
Any suggestions how to investigate this further or what else to try ?
Check the wiki to see if your carrier info is there. If not, you will need to contact your provider's tech support and get config info from them. Review the wiki regarding VoLTE either way
  Phone powers off with high user demands car46999 7 1,303 04-11-2024, 09:17 AM
Last Post: zetabeta
  No calls in or out on beta IsaiahSp 0 792 09-28-2023, 10:44 PM
Last Post: IsaiahSp
  Phone will not turn on (but sometimes will) insidetrip101 10 5,540 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 1,252 07-31-2023, 07:50 PM
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,291 02-20-2023, 12:14 AM
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 1,521 02-15-2023, 11:21 AM
Last Post: fxc
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 25,716 01-29-2023, 12:20 PM
Last Post: skandigraun
  I cannot call or receive calls aka0kuro 6 3,558 01-13-2023, 05:31 PM
Last Post: alaraajavamma
  BETA edition rcu errors 8bit 29 21,989 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
Thumbs Down Phone is unresponsive theneedful 14 8,680 08-12-2022, 08:18 AM
Last Post: theneedful
