Gnome settings crashes in Mobian after magnification change.
I restarted my installation of Mobian on the SD card in the PinePhone Pro. It works well after a dist-upgrade on October 28, 2022.
But I changed the screen magnification in gnome settings, which resulted in gnome settings crashing on its startup. The solution is to delete the binary format file, ~/.config/dconf/user .
Thank you for your post, mburns. This bug was driving me crazy!
After daily updates as of November 24, my copy of Mobian is disabled. the console, Settings, and other applications crash.
OK now! Mobian is back in working order after an update as of 8:36am EST. But clicking on some options in Settings will crash it.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 12 1,813 56 minutes ago
Last Post: zetabeta
  Disable the GDM service in Mobian. mburns 0 466 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 883 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 500 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 708 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 601 10-14-2023, 11:57 AM
Last Post: mburns
  Stupid UI Question (PPP/Gnome?) dwellerbelow 3 802 10-12-2023, 07:07 PM
Last Post: dwellerbelow
  Mobian libnotify custom notifications MadameMalady 5 1,403 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,152 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 800 07-01-2023, 08:18 AM
