Case for Pinephone
(08-07-2022, 05:53 AM)kuleszdl Wrote: Hi folks,
I bought two cases of phones with "similar" shapes, namely the Galaxy S20 Ultra (Otterbox Symmetry) and the Mate 9X Lite ("Fashion Design Personality Case"). Both are not what I was looking for - the gap is fixable with a 3d printed placeholder, however, due to PP being wider, you just can't put the phone face down in the case - not even thinking about dropping it. Hence, you never get any kind of Otterbox-like experience. :-(
Any suggestions for other phone models with a similar depth of the PP?
I guess I will have to try one of the fully 3D printed ones. Any recommendations regarding the material?
Other than that, I thought about getting the Otterbox Defender (Pro) for the S20 Ultra and "hacking" it.
If I were going to print a case I would make a TPU inner soft 'bumper' case and a nylon outer hard shell though ABS filament is also tough and easier to find.
There is a linked model for a 'negative' above so it should be pretty easy to use that to remove the shape from a simple shell on OpenSCAD or whatever you use.  You just need to add through holes for switches, USB and audio.
Hi all, a leather flip case for PinePhone Pro, does anything like that exist?
I see www.fitbag.com can make a case for the PPP but it looks like it can fall out because there is no closure, and the fabric looks soft.
@User 16030 which case did you use in https://forum.pine64.org/showthread.php?...4#pid68604 ?
I'd like to create my own in genuine leather, but raw materials are rather expensive, unfortunately. And, I don't know if it's worth going straight to synthetic leather when I'd like to keep a spirit of authenticity all the same for my Pinephone. Any recommendations?
Just in case there is someone else out there looking for a cheaper close-enough fitting case, I can confirm that this Otterbox case for the Moto G7 Power works:
https://www.amazon.com/OtterBox-Commuter...B07QWQKPQK
The side buttons are slightly misaligned, but I managed to work around this by carving the existing button indentations on the inner soft rubber portion of the case. The only other caveat is that the headphone jack alignment is slightly off, but the existing hole on the case could likely be expanded via a drill or dremel tool.
  Getting started with fingerprint scanner case lolgzs 1 1,074 09-08-2024, 04:21 AM
Last Post: mfashby
  Seeking your experiences: PinePhone in snug cases of other phones mycycles 9 4,521 08-16-2024, 06:19 AM
Last Post: 67man
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 3,634 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 1,265 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 464 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 187 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 710 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 956 06-26-2024, 07:11 AM
Last Post: dachalife
  Troubleshooting Pinedio LoRa Add-on Case nickp 1 423 06-17-2024, 10:15 PM
  Slip/Zippered Case for PP/KB? jakfish 0 479 03-03-2024, 04:55 PM
Last Post: jakfish
