Keyboard function keys F1-F10
Hi
I don't think it's limited to Mobian or Phosh, but I can't get the F1 to F10 keys to work.
I can use the Fn + number to get the other characters/symbols, although it's a known issue that some of those are incorrect at the moment.  As far as I know, you use the Pine/Super L key as the modifier for the actual functions, but that just outputs the number, as if you hadn't used the Pine key.
The Pine key registers as Super L in xev, so it's doing something at least.
Curious if anyone has or hasn't got these keys to work as expected, and if they have got them working, what was involved in doing that.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,440 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,058 12-23-2025, 04:25 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,680 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 6,169 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 41,251 01-13-2025, 01:37 AM
  Keyboard not popping up on QT apps 3x5co 1 3,474 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 3,167 10-29-2023, 08:34 AM
Last Post: walter1950
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 4,300 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,854 12-22-2022, 07:10 PM
Last Post: acid andy
  Would creating a 2 row landscape keyboard be difficult? rp3 1 3,514 09-09-2022, 06:49 AM
Last Post: zetabeta
