Add additional modules before you ship the PINE A64
(02-11-2016, 03:24 AM)avinashga23 Wrote: I have pre ordered one 2GB unit. I need to add a wifi module to it, Also i want to buy 4 more boards with wifi modules. will the upgrade also apply to preordered ones too?
If you mean the 2GB RAM upgrade, I would presume you can choose four extra 2GB Pines and five WiFi modules, yes. That should not be a problem (board limit is 10).
(02-11-2016, 01:41 AM)huckfidle Wrote: I am not sure what basic add-ons are required. I just need the pine64 for internet streaming sports websites, Netflix, general surfing from Australia. I have pledged the 2g board
You need some sort of 5v 2a micro usb power supply and a hdmi cable. That's it.
If you want WiFi and/or Bluetooth, you could get the combined WiFi/Bluetooth module, but the Pine does have an Ethernet port built-in, so if you're happy with that, all you need is the power supply and hdmi.
(Note that the necessary power supply utilises more current than the average smartphone/tablet charger can provide)
Well, it probably depends on what else you have lying around.
If you don't have other 2 amp USB 2.0 power supplies with a micro-USB cable already, you probably want the 2A international power supply. Note, some so-called smart USB chargers will only deliver 2A of power if they recognize the phone that is connected. Otherwise, they will only deliver the 500mA that the USB 2.x standard requires.
Unless you have your own HDMI display and don't need the touch screen support, you probably want the 7" LCD touchscreen display.
Unless you were going to connect your pine64 to the internet via wired ethernet, you probably want the bluetooth/wifi add-on card. You might be able to use existing USB wifi or bluetooth adapters, but I don't think the pine64 team has released which ones are compatible.
From other posts, the 8000mAh battery might not be available, as it is getting harder to ship these batteries due to various devices catching fire. If you want to run it on battery support, you might find a cell phone USB charger battery with at least 8000mAh that can deliver 2A of power from a vendor that ships to your area.
Whether you want the camera, air mouse remote, basic media remote, or the various cases depends on what you want to do with your pine64.
The real time clock battery module is only needed if you plan to use the pine64 without connecting it to the network, particularly if you are going to be running on batteries.
You might want to pick up a USB mouse/keyboard if you don't have extras lying around. A powered USB 2.0 hub might also be useful to allow you to connect multiple USB devices and/or use higher powered devices.
I have a $89 pledge , could I add a 5MP camera module? On backerkit survey, they say it works only with $19 & $29 plegde.
The T-Shirt shipping to Spain is 999$, there are something wrong... Smile
(02-17-2016, 01:53 AM)Arkhanjel Wrote: The T-Shirt shipping to Spain is 999$, there are something wrong... Smile
All apparels currently ship to US only, thus it's $999 for all other countries.
Ok, thank you. I didn't read it.
I confirm my pledge and ADD-ON ITEMS, but i would like to add another add on.. Can I?
delete addon
(02-17-2016, 12:02 AM)hienhuynh1982 Wrote: I have a $89 pledge , could I add a 5MP camera module? On backerkit survey, they say it works only with $19 & $29 plegde.
The camera module will work fine with the $89 pledge. The only pledge level it won't work with are the $15 and $5 pledge, as these lower levels do not have the necessary interface onboard to support the camera module.
The $89 tier reward level will work with the camera module.
#19
Hi hazety, you can refer to the link from your survey to reselect your desired items.
Sent from my iPhone using Tapatalk
Board: Pine A64+ 2GB board.
MicroSD: Samsung Evo/+ 32/64GB
#20
The $999 just means no available ship to Spain.
  Pine 64 installer OS list blank spamsucks 1 1,115 04-08-2025, 08:16 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 3,323 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 1,349 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 6,287 07-03-2022, 02:18 PM
Last Post: Dude
  Cannot ship, need USB SERIAL CONSOLE/PROGRAMMER alternative please JuniperFury 5 8,681 10-29-2021, 07:13 AM
Last Post: TRS-80
  Pine A64+ vs LCD do not boot DDS 3 7,894 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 4,433 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 5,574 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 9,812 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 3,514 12-16-2019, 04:21 PM
Last Post: DonFL
