No Display on PBP
I have a similar issue to some I've seen here, but not identical.
My PBP was working fine two days ago on Manjaro from eMMC, but when I booted it yesterday, I had absolutely nothing on my display.
The LED  starts off red for a few seconds, then goes green.  The numlock/capslock keys toggle the appropriate LEDs.
I've tried hitting ESC after a few minutes, but still nothing.
I loaded Manjaro KDE to a USB stick.  When I boot with it inserted, I get activity on the stick's LED to show that it's being accessed, but still, not even a flicker on the display.
Also no luck booting from SD.
If I had to place money on it, I'd guess that the machine is booting, but the display is dead.  Is there any keystroke combination that could have turned off the display? I've already tried Fn + F2 to turn up brightness.
As a followup, I opened up the case and flipped the eMMC switch away from the hinge. At that point, I got ABSOLUTELY nothing, not even the LEDs.
I switched it back and I'm now back to square 1.
Try ssh to it? You might have to do "blind login" for wifi to be active
Do give it enough time for the connection to be alive
Well, I hope you do not have a dead LCD display that would suck Sad
You could inspect the eDP connector both ends of the cable to check they have not fallen out (obviously the panel end is difficult to get to -- there are other things you could prioritise to check first, checking this connector only as a last resort before actually buying fitting a new LCD panel). Checking the cable for damage too.
Did you ever use USB-C to HDMI? You could see if there is any video on an external monitor. And if there is, that might help diagnose things.
Remotely SSH'ing in to PBP to check dmesg, logs etc.
  PinebookPro Display Corrupts/Cuts Out Twig 5 7,221 06-11-2023, 07:59 AM
  PBP green LED works but blank display. frerebo 1 3,874 02-22-2023, 03:11 AM
  Lost my second display WEF 5 10,021 08-18-2022, 07:53 AM
Last Post: josmo
  Issues with External Display After Recent Update reundo 0 3,665 11-18-2021, 06:37 PM
Last Post: reundo
  Pinebook Pro - Display cable broken? snokis 0 4,527 08-17-2021, 11:30 AM
Last Post: snokis
  pinebook pro dock display out mamboman777 0 2,975 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 7,369 07-19-2021, 04:00 PM
Last Post: jbrock
  [split] U-Boot with NVMe support, keyboard & display working as400 78 143,443 01-27-2021, 12:48 AM
Last Post: as400
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 15,424 12-30-2020, 06:14 AM
Last Post: BetteHoward
Shocked flickering vignette display? plarkinjr 4 9,931 07-06-2020, 04:16 PM
Last Post: Alstroplane
