[phosh] boost pipewire volume beyond 100%?
My earpiece speaker broke after my Pinephone fell out of my jacket pocket. I bought a replacement speaker from aliexpress based on a post identifying compatible models but, even though it works, the volume is very low even at 100%.
With pulseaudio I would use pavucontrol to boost to 150%. Manjaro Phosh uses pipewire and pavucontrol doesn't work. Does anyone know what I can use to achieve the same result. Speaker is unusable as there is a massive echo so callers hear themselves, and I would like to be able to use the earpiece rather than having to use an earpiece - though that is the best solution, I think, once you've managed to untangle it, push in the earpieces and plug it in!
Command line would be fine, ideally something that survives reboot.
Thanks.
I did stumble across an app in Manjaro Phosh's software repository called "Tweaks." It has a toggle switch that boosts pipewires audio above 100% for me. Just warn you now that depending on your application the audio gets more distorted the louder you go. For calls it might work fine but for music you might want a better option.
(09-01-2021, 08:44 PM)AwHereWeGoAgain Wrote: I did stumble across an app in Manjaro Phosh's software repository called "Tweaks."  It has a toggle switch that boosts pipewires audio above 100% for me.  Just warn you now that depending on your application the audio gets more distorted the louder you go.  For calls it might work fine but for music you might want a better option.
Thanks, I'll give that a try.
Great, thank you Smile
See: https://forum.pine64.org/showthread.php?...#pid101571
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,764 04-25-2023, 09:49 AM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,621 02-24-2023, 12:56 PM
Last Post: jakfish
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 2,999 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 5,901 09-05-2022, 03:42 PM
Last Post: nroth
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 4,795 04-07-2022, 06:02 AM
Last Post: danimations
  Manjaro Phosh Issues Csanderson0313 7 12,262 03-05-2022, 08:23 AM
Last Post: Csanderson0313
  No wifi with phosh image wave22 3 6,303 02-15-2022, 07:25 AM
Last Post: wave22
  How to remove Manjaro Phosh lock screen password? Avisando 4 8,509 10-28-2021, 04:20 AM
Last Post: Avisando
  How can I update Manjaro ARM w/ Phosh using Terminal? danimations 6 10,242 10-24-2021, 11:58 PM
  Issue with Calls on Phosh Barugon 4 7,754 10-15-2021, 05:46 AM
Last Post: Johnmash2
