Crash when Updating Manjaro-Plasma. Hanging on "checking available disk space"
Good evening. I acquired a Pinephone – Beta Edition with Convergence Package back in March and initially found the operating system to crash continually. I came back a couple of months later to it and tried to update the Manjaro to see if things had improved. After several hours of putting error messages into Google I have manged to get the phone mostly updated apart from an error which I believe is near the tail end of the process.
The issue is that the Pinephone seems to become unresponsive whilst "checking available disk space". I have no idea why this is happening.
Last few lines of SSH terminal:
Quote:Total Installed Size:  3775.60 MiB
Net Upgrade Size:      244.18 MiB
:: Proceed with installation? [Y/n]
(453/453) checking keys in keyring                   [#############################################] 100%
(453/453) checking package integrity                [#############################################] 100%
(453/453) loading package files                          [#############################################] 100%
(453/453) checking for file conflicts                    [#############################################] 100%
( 87/457) checking available disk space              [########-------------------------------------]  19%
I have checked the disk space itself:
Quote:[username@plasma-mobile ~]$ df -h
Filesystem      Size  Used Avail Use% Mounted on
dev            1.4G    0  1.4G  0% /dev
run            1.5G  9.4M  1.5G  1% /run
/dev/mmcblk2p2  29G  5.8G  22G  22% /
tmpfs          1.5G    0  1.5G  0% /dev/shm
tmpfs          4.0M    0  4.0M  0% /sys/fs/cgroup
tmpfs          1.5G  60K  1.5G  1% /tmp
/dev/mmcblk2p1  214M  37M  177M  18% /boot
tmpfs          300M  48K  300M  1% /run/user/1002
As well as the current Distro and GUI versions:
Quote:[username@plasma-mobile ~]$ hostnamectl
  Static hostname: plasma-mobile
        Icon name: computer-handset
          Chassis: handset
        Machine ID: 71fdd7dcc5db4aeba9bec02b1fc96dc8
          Boot ID: c1b8b7c5c2b64215a9fb6d2539f73bd7
  Operating System: Manjaro ARM
            Kernel: Linux 5.11.3-1-MANJARO-ARM
      Architecture: arm64
[username@plasma-mobile ~]$ plasmashell --version
plasmashell 5.21.2
[username@plasma-mobile ~]$ kf5-config --version
Qt: 5.15.2
KDE Frameworks: 5.79.0
kf5-config: 1.0
Other details that might be relevant are that I have also experienced the screen flicker / going blank since embarking on the update process and that I the power brick I am using is an Apple iPhone /iPad one which is below the recommended specifications (15W – 5V 3A from store page) at only 5V 1A.
Any help with this issue would be much appreciated, even if it is just pointing to a pre-existing article fixing this problem.
Kind regards,
A new Pinephone owner.
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 21,532 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,889 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,045 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 3,242 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 16,585 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 6,900 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,611 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,061 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 3,402 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 16,547 01-25-2023, 04:15 PM
