Centos 8 Stream on Rock64
So I followed along the guide to install CentOS 7 referenced on the Wiki (and noted on the thread here: https://forum.pine64.org/showthread.php?...&pid=95685 and the guide on the developer's site here: https://project31.github.io/pine64/), and decided to give upgrading to CentOS 8 and then switching to Stream a try.
I followed a few guides online (specifically here https://www.tecmint.com/upgrade-centos-7-to-centos-8/ and here https://linux.web.cern.ch/centos8/docs/migration/), and with a tad extra fiddling to handle the kernel version, I was able to get fully updated and now am booting into CentOS stream!
My question is that upgrading 7 - 8 isn't technically supported, so I would like to try making an updated image for Stream 8.
The Project31 site has some info linking to it's inspiring project, which mentions taking the AArch64 image and a booting Armbian image and swapping out the rootfs bits while preserving the the /boot, /lib/modules, and /lib/firmware (here: https://github.com/umiddelb/aarch64/wiki...ch64-board)
When I try to follow up on this, I cannot seem to figure out how to take the images available on the CentOS site and extract the rootfs.... Can anyone point me in the right direction?
Thank you for your help, and your patience!
Have you tried the procedure that works with CentOS 7?
https://www.thegeekdiary.com/centos-rhel...itview-it/
it doesn't get happy
it doesn't get sad
it just runs programs
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,141 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,707 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 95,916 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,988 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,387 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,379 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,913 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,089 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,978 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,495 09-01-2024, 06:05 AM
Last Post: RaymondDay
