Pinebook Pro Docking Deck Ethernet Port
Good day everyone.
I'm in need of some assistance.  I have my pinebook pro attached to the Pine 64 docking deck and having some trouble with the deck's ethernet port.  I have USB-C power going into the docking deck along with an external HDMI monitor plugged into the HDMI port. I then have the deck's ethernet port connected to my network switch.  The problem i'm haviing is that when I power up the pinebook pro, the ethernet port doesn't activate and connect to my network.  This happens more time then not.  Once in awhile it will connect on power up, but mostly I will put the pinebook to sleep and then wake it up and then the ethernet port will activate.  Does anyone have a solution?  Thanks.
/Mike
Hey there! I-m having the exact same issue with the ethernet port and the docking deck, have you found a solution yet?, Btw have you tried the audio jack in the docking deck?, I can't make it work, so I wonder if the two issues are related.
  Replacement battery for PineBook Pro DrYak 5 6,198 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,694 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,421 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 3,997 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,575 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,523 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,076 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 207,987 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 13,317 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 11,675 12-27-2022, 03:31 PM
Last Post: samtux
