battery problem
hello,
i received my pinephone yesterday (manjaro-arm) and followed instructions for removing plastic between battery and contact. it seemed to be behaving normally while charging via usb other than the battery charge not getting past 90% and then moving backwards!? this morning i started the phone on battery power alone and it turns on, shows the gear and the K logo and then goes dark. when i make contact with the screen, i can see the numerical pad but as soon as i break contact with the screen it goes dark again. everything works normally once i connect the usb power cable. energy settings are on 'never' for lock screen and sleep and 5 minutes for turn off screen. any input would be appreciated, thanks.
Your battery is OK. Just Settings -> Screen setup application writes wrong values to the /.config/powermanagementprofilesrc file:
https://forum.pine64.org/showthread.php?tid=13481
You can manually edit the file like in this post:
https://forum.pine64.org/showthread.php?...8#pid93468
hi, appreciate the reply! i will look into this this evening. please remind me, haven't been using linux for awhile, that rc file is in my home directory? and i assume i'll be working from the terminal/shell - what editor would i be using in plasma-mobile? thanks.
(04-30-2021, 06:37 AM)Rainer Wrote: hi, appreciate the reply! i will look into this this evening. please remind me, haven't been using linux for awhile, that rc file is in my home directory? and i assume i'll be working from the terminal/shell - what editor would i be using in plasma-mobile? thanks.
Yes, the file is in your home directory. I just used the default file manager Index, set it to show hidden files, long press on powermanagementprofilesrc file, open with Nota editor, edited the file and saved. The changes are in effect immediately.
this worked - thanks a bunch! a little nerve-wracking working with that editor and a config file on a phone but it all worked out.
  Battery life improvement freelectro 11 13,232 09-14-2026, 08:53 AM
Last Post: Juergen
  Battery connector dead mdk 5 5,455 01-15-2026, 02:24 PM
Last Post: mikeb
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 7,074 02-05-2025, 02:30 AM
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,003 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,423 02-17-2024, 04:15 PM
Last Post: vortex
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,631 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 13,975 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,892 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 53,613 02-26-2022, 02:07 AM
Last Post: vusra
  Pinephone time goes too slow (not a 2115 year problem) grwlf 1 3,739 02-06-2022, 05:05 AM
Last Post: grwlf
