Manjaro Plasmamobile not booting after update [Solved?]
I put the beta2 of plasmamobile on a card and have been booting off that. It did a fairly large update a few days ago, which worked without a problem. Today's update, though, gets me nowhere except a K-gear icon and a black screen.
The cursor is there and responds as normal to touch, but nothing else. It doesn't even drop to command line.
Anyone else having this issue? And have any fixes?  Before I reinstall from a new image.
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
(03-29-2021, 10:36 PM)quixote Wrote: I put the beta2 of plasmamobile on a card and have been booting off that. It did a fairly large update a few days ago, which worked without a problem. Today's update, though, gets me nowhere except a K-gear icon and a black screen.
Same here, I ended up reflashing mine
Not exactly the same here, but the update installation stalled.
After downloading the packages it rebooted and started to install updates. At least the screen said so. After about one hour the it still displayed the same message. Forced a reboot. After the reboot packages database was locked. Deleted the file /var/lib/pacman/db.lck and performed the update using pacman: sudo pacman -Syu
(03-30-2021, 12:27 PM)acrux Wrote: ... Deleted the file /var/lib/pacman/db.lck and performed the update using pacman: sudo pacman -Syu
Interesting. I'm assuming you got at the file system from a connected desktop?
The pattern you describe was exactly what I got. I was just less clear about the details.
Nope, my pinephone doesn't show up at all on my desktop Debian system.
How did you actually get at the filesystem on the phone?
(03-30-2021, 11:42 PM)quixote Wrote: How did you actually get at the filesystem on the phone?
I did not use a computer. As I wrote, I was lucky to get the phone's Plasma Desktop up after cancelling the update and used the phone's terminal for "sudo pacman -Syu"
Same here, installed a large update a few days ago. Another smaller one (~3xx MB) today. Rebooted, install took a while, rebooted itself and then was just stuck.
Now I don't get further than the KDE gear - it stopped spinning and I have a mouse courser which moves when I touch the screen.
Unless anyone has a better solution, will re-flash the latest version on my SD tomorrow.
Bit odd that there's no info from Those Who Know (Manjaro pinephone devs??) what's going on and when this is likely to be fixed.
I also downloaded and installed latest version ... and same problem! Boot stops at K-gear with working mouse and nothing else.
In my case it could be that it's just not going to work with a braveheart phone, in which case no point trying to solve the problem.  Which is kind of sad.
What I'm hoping for at this point is some indication of which "latest version" has actually dealt with this issue and is worth downloading and installing. It gets old, prying apart the poor phone, reinstalling, and staring at the same black screen!
I downloaded the latest dev version (202104060258) from github (https://github.com/manjaro-pinephone/pla...e/releases), just to see if that made a difference.
The good news is it does. It boots. W00T. Got a nice first-boot welcome sequence too that allows you to set locale and such.
The bad news is the phone doesn't work 'out of the box'. (Shriek) Meaning, it doesn't seem to see my carrier's SIM which is right there. I'll have to go see what ofonoctl can do...
Well, just now when I looked at the phone again after a couple of days there were 57 updates. Went ahead with them, restarted phone, aaaand...
Calloo, callay! Calling works, texting works.
Can't wait to use it as a daily phone!
  Using too much juice since last update Eugo 20 22,438 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 14,144 02-13-2024, 01:19 AM
  Manjaro: Settings doesnt open nbh 0 3,342 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,207 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,138 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,696 04-25-2023, 09:49 AM
Last Post: jakfish
  Latest update Eugo 21 25,030 03-09-2023, 05:27 AM
Last Post: Eugo
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,513 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 3,505 02-09-2023, 08:17 AM
  Firefox issue with latest update Barugon 6 8,493 01-28-2023, 01:29 AM
Last Post: alaraajavamma
