Pine64 to TV mode not supported
(07-19-2016, 08:57 AM)brianr0922 Wrote: Hi tllim, I have noticed one problem with the files.  Previous 64Gb images were 63.3Gb (63,282,610,176), which worked fine on all the SD cards I have, but the new one is 64.5Gb (64,490,569,728) which is too big.  A normal 64Gb SD card is not that big.  Can you possibly remake the images a little under 64Gb?  It would be really helpful.  Thanks in advance for your help.
Noted, I will revisit the microSD images size and rebuild using smaller size one.
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 8,671 10-21-2025, 10:13 AM
  stuck to sleep mode pinecil v2 lilibit 3 4,638 12-11-2023, 04:18 PM
Last Post: lilibit
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,119 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 5,831 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 8,846 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 5,779 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 193,318 01-15-2020, 12:46 PM
  A list of supported OSes would be helpful blicken 2 7,011 01-06-2020, 04:20 PM
Last Post: bcnaz
  Emails from pine64 received as spam by gmail Matan 2 13,295 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 20,804 03-28-2019, 11:43 PM
Last Post: InsideJob
