POCSAG Pinephone Hardware Add-On; Radio Silence, Privacy, Anonymity,and Freedom
I took a look at this IC, what do you all think about this as the receiver, since it has a TX function too it could be used to do many other things(especially if we bypass our POCSAG mode band-passes) including short range paging other Pinephones(or pagers), WSPR, or LoRa, maybe even FM audio tx for older cars(though the datasheet says FSK is the tx mode); perhaps a switchable power TX amp for greater range for licensed amateur radio ops on their freqs. If we can do that POCSAG will just be one function(will need another decoder than just the POCSAG hardware decoder IC, maybe an i2c sound card?) of a very useful pogo-pin add on without needing to go full HackRF.
https://www.ti.com/lit/ds/symlink/cc1000.pdf
I have not been able to move forward without this key IC but together I think we could start populating a breadboard once I hear some comments, my main concern is sensitivity though a LNA preamp might help while burning power.
Since this would require a controller anyways to keep power down I think my go-to attiny85 could bridge the i2c needs of both the RF transceiver and the decoder chips; also a very stable crystal so we can do more freq sensitive stuff than just wider band POCSAG signals.
Input from experienced RF engineers is key to choosing a good IC candidate as my experience with radio design is almost exclusively power hungry SDRs or discreet component QRP sets maybe with a DDS for HF that may not be as efficient, small, or sensitive as we will want for this project and all have had high part count.
RE: POCSAG, Radio Silence, and Freedom - by tllim - 09-05-2020, 06:21 PM
RE: POCSAG, Radio Silence, and Freedom - by bcnaz - 09-05-2020, 07:45 PM
RE: POCSAG, Radio Silence, and Freedom - by biketool - 07-20-2021, 03:14 AM
RE: POCSAG, Radio Silence, and Freedom - by tllim - 08-07-2021, 10:25 PM
RE: POCSAG, Radio Silence, and Freedom - by tllim - 08-09-2021, 09:28 PM
  Case for Pinephone totilele 13 7,303 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 644 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,203 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 457 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 524 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,026 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,459 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,056 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,553 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 642 08-04-2023, 10:47 PM
Last Post: jnpine
