Mobian and WiFi
Hi - I am a very new owner of a pinephone and have been trying Mobian.  I have not installed a sim card and I am running Mobian from an SD.  I can connect to home WiFi and the UI is easy to understand and use.  My trouble is that apps seem not to be able to use the WiFi.  For example neither browser can connect to any website and Geary can not connect to email servers.  It seems as if there is some setting that I am missing or that a sim card is required.I have checked the Mobian gitlab issues and have found nothing. Any insight? Regards and thanks.
Make sure battery fully charged otherwise wifi connection will be difficult. Used to work fine up to a nearly dead battery on an earlier software version.
I have the Pinephone UBports CE. I'm running Mobian (nightly from 2020-08-17 if I'm not mistaken) from SD card and my WiFi is working fine. I don't have a SIM card in my phone.
So I'm not sure what can be causing your issue. Maybe you could run "King's Cross" (Mobian's terminal program) and ping your router and some external server, and use 'host' to check that DNS is working? The results should give a clue as to where the problem lies.
First, thanks for the replies and suggestions!
Today I started from a completely off state.  After a bit, the wifi kicked in and apps were able to use it.  So, now I am off to try various apps.
  Mobian MMS/SMS text problem bcnaz 16 37,768 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,513 04-27-2026, 09:57 AM
Last Post: Korfou
  reset wifi hardware/driver when it dies through console on pp? tuxcall 5 6,849 03-10-2026, 04:43 PM
Last Post: baptx
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 65,535 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,793 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,244 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,747 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,925 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,011 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,722 05-06-2025, 02:19 AM
