Screen has to be on to comunicate with phone
Hi
I installed ssh and samba and they work fine. No problems to communicate with the phone.
However, to be able to connect via ssh or samba, the screen has to be on. If phone is left unattended, screens turn black and communication stops.
is phone sleeping when the screen turns black? I checked in Power settings, and the Black screen can be modified. This should only save energy for the screen but not sleep the phone, or does it?
In my experience this happens when crust kicks in to put the phone to sleep. I believe this is the case because this causes the wifi to cut out which would obviously make ssh lose the connection.
Turn off the default 'sleep after 5 minutes' in the Power settings, or leave the phone plugged into a charger.
good catch!
something to be fixed!
  On-Screen Keyboard Arrow Keys biketool 10 2,099 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 830 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 5,952 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 1,263 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 1,259 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 11,043 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 2,096 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,642 01-13-2023, 03:33 AM
Last Post: mdk
  phone does not ring (when sleeping) jsch 2 3,023 10-07-2022, 08:08 AM
Last Post: alaraajavamma
  how to split screen? andrew907 2 2,832 08-08-2022, 09:38 AM
Last Post: andrew907
