Working Android
I do not know why but I have tried every version of Android listed in the wiki, and none of them will work on my Pine.  I have the 64+ 1GB board.  I can get Android to boot.  I can connect the wifi and get to the internet.  And that is it.
The Play Store crashes every time I attempt to use it.  Normally I can click 3 to 5 times and as soon as I attempt to download an app, it stops responding then just closes.  If I try it after the first crash, it will just shut down immediately with the first thing I click.
So I have downloaded the APK file for a couple different apps.  I can attach a USB stick, ES File opens it up.  But when I attempt to install any of the APK files, the installation fails.
Does anyone know where I can find an Android image that actually allows me to install apps?
Current build working well (Android 20160505), PlayMarket crash is typical problem, you can use your PC to install Apps from PlayMarket to you Pine (just log in via Google and click "set up to my Pine".
Problem with apk on usb-stick is very strange. Maybe rewrite the image of android?
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,439 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 572,793 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 46,668 12-23-2020, 06:11 AM
Last Post: Learnincurve
  3,5mm audio out not working MikkoL 9 22,038 11-22-2020, 06:42 AM
Last Post: Little_Johnny
  Adding an accelerometer to Android modsbyus 11 29,774 11-02-2020, 08:12 PM
  MTP Stopped Working miller08 0 4,480 12-24-2019, 02:42 AM
Last Post: miller08
  Android Things OS dqvsra 2 11,704 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,051 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,703 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,156 07-15-2019, 08:29 PM
