Battery replacement alternative
Ordering a battery from the Pinestore is sometimes expensive for the shipment and import taxes.
Looking for an alternative I've ordered the PATONA Battery EB-BJ700CBE 3000mAh on Amazon.
So far seems to last more than the original battery and reaches the 75% as maximum.
Pinephone CE
I just purchased a Samsung battery on ebay,  it is a perfect physical fit into my Pine phone.
  I used the battery spec's from the Pine Wiki in my search.
>> New OEM Battery For Samsung Galaxy J7 SM-J700 J700M J700P J700F EB-BJ700CBE <<
Only difference I see so far is the Samsung is rated at 3000mAh, while the Pine is rated 2800mAh, not much of a difference.
I charged it on the external 'Pine' charger for 4 - 5 hours,  then installed it into my PMOS convergence phone running a recent Mobian Nightly release on sd card.
It showed 100% charge at that time.
Five hours in and it is showing 88% charge.    $8.43 USD delivered to my mailbox.
I will update this post in a few days and share what I think at that point,  Hopefully Good News.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(08-07-2021, 05:13 AM)bcnaz Wrote: I just purchased a Samsung battery on ebay,   it is a perfect physical fit into my Pine phone.
You can peel off the plastic cover and the actual battery capacity may print on the metal case.
(08-07-2021, 05:13 AM)bcnaz Wrote:  I just purchased a Samsung battery on Ebay :
August 27, 2021
UPDATE :
    The Samsung battery seems comparable to the Pine battery in discharge rates, but it appears to charge just a little bit faster, at least in my case/usage.
***** the Pine battery has been 'in use' about a year plus,    while the Samsung just started soo.....
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
bcnaz, I got one of those on your recommendation, with similar good results. Thanks.
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
The Samsung battery I received did have the little Holographic dot on it,  so maybe it is a 'real' Samsung battery ?
That particular vender seems to have 'sold out' at this time, and none of the others seem to have Genuine Samsung,     just OEM replacements.
Aug. 28, 2021
Update : the ebay guy got some more in stock, SO I ordered another spare
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Manufacturers of fakes were putting holograms on them a long time ago, so that's not a reliable indicator.
You are absolutely correct about that
However, so far the battery appears to be satisfactory, I'm just sharing my thoughts as I go.
It is a fairly inexpensive item to purchase, and it could prove handy to have a spare.
>> I should mention that I have noticed that when I do swap the batteries, the time seems to get changed in the operating system.
Not a huge deal, but worth mentioning.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Battery connector dead mdk 5 3,375 01-15-2026, 02:24 PM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 10,069 02-24-2025, 06:55 AM
Last Post: anonymous
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 2,670 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,472 02-17-2024, 04:15 PM
Last Post: vortex
Question Alternative Designs or Materials for the Back Cover? BMayes 2 2,705 12-18-2023, 11:19 AM
Last Post: BMayes
  Replacement screen disconnects after back frame is screwed on robthebold 4 5,500 10-12-2023, 01:03 PM
Last Post: robthebold
  Battery life improvement freelectro 10 10,380 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 4,731 03-20-2023, 12:54 AM
Last Post: bcoyle
  Microphone replacement SocialNetworkingWasAMistake 1 3,471 08-05-2022, 03:16 PM
Last Post: calinb
  Power supply vs battery albafrati 11 11,432 06-22-2022, 06:04 PM
Last Post: albafrati
