KDE password
Hi All,
I changed my password to something containing letters and numbers on my pinephone community KDE.
But the login screen only has numbers.
How do I change it from my PC over USB?
Hi, if you have ssh enabled, then just ssh in and change the password.
if not, if you can plug in a USB keyboard, then you can try switching to a tty ( ctrl + alt + <F1..F6> ). From there you can log in and change your password.
Alternatively, you could boot to another OS and chroot from there. If the OS that you've locked yourself out of is on the eMMC, then boot from an SD card, then mount the necessary partitions from the eMMC and chroot into it, then change the password.
Hope that helps
  Default password for KDE plasma pine phone Toni 0 8,324 09-14-2025, 06:35 PM
Last Post: Toni
  Clamares password needed with new Mobian installation fauvetan 1 3,181 06-26-2025, 03:00 AM
Last Post: merom
  Turn off password reginaborder 2 3,507 07-04-2024, 01:53 AM
Last Post: Gumur
  Lost password on second hand Ubports PinePhone? Peter Gamma 6 8,812 04-10-2022, 01:20 PM
Last Post: Peter Gamma
  Pinephone won't let me enter password czgunner 5 9,402 09-07-2021, 08:50 PM
Last Post: TRS-80
  What is the first-time password? Chupacabra 10 22,978 03-29-2021, 09:43 AM
Last Post: Puro Antinori
  PinePhone Pin/password question dgdimick 3 7,761 03-28-2021, 06:32 PM
Last Post: dgdimick
  I am stuck, When in Terminal, unable to enter a password Whio84 3 6,109 02-12-2021, 03:46 PM
Last Post: Whio84
  Default Password for New Pine64 KDE Plasma CE? robertb1 3 9,243 02-01-2021, 04:29 PM
Last Post: cybercricket
  default password for Manjaro pinephone Raniyah 1 6,318 11-23-2020, 11:50 PM
Last Post: kqlnut
