Help! - Screen blank after update.
Sad
I have had UB Ports running on my Pinephone for a year, not as my daily driver, but as a backup phone, also trying out various new apps available.
I kept it on the kernel update channel and everything seemed fine. However, following one of my last updates, the screen goes blank after bootup. Apparently, the phone is running Ubuntu, but the screen does not show anything. How can I fix this?
I would hate having to kill my long-standing installation.
Many thanks for your thoughts on this problem.
Several months ago when the kernel channel came out there was a bug that sometimes prevented the phone to fully boot. It was easily recognized because the led was constantly glowing red. If that's your issue you basically have to reboot your phone until it eventually continues the boot process.
(07-26-2021, 05:00 AM)Nooblife Wrote: Several months ago when the kernel channel came out there was a bug that sometimes prevented the phone to fully boot. It was easily recognized because the led was constantly glowing red. If that's your issue you basically have to reboot your phone until it eventually continues the boot process.
No, it seems to boot fully.  When I kill the phone (10 sec power button), it briefly shows my screen as it should be. But that's too late to do anything, just before it switches off.
Sorry i can't be any help. The easiest solution is probably to reinstall, or you can ask on the official ubports forums.
Thanks for replying anyway.
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 2,837 05-12-2023, 05:06 AM
Last Post: c3l@
  Screen-off = dead phone okgo 11 19,402 09-27-2021, 07:53 PM
Last Post: jtn0514
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 10,503 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  How to find out about package versions on different update channels? kqlnut 0 4,346 08-30-2021, 01:38 PM
Last Post: kqlnut
  What does an OTA Update look like lsitongia 0 4,203 08-24-2021, 10:20 AM
Last Post: lsitongia
  Update Channels & Kernel Version mark1250 2 5,610 03-20-2021, 08:26 AM
Last Post: mark1250
  noticable Screen flicker KNERD 0 3,180 01-13-2021, 09:00 PM
Last Post: KNERD
  Kernel update failing issues KNERD 5 10,646 01-10-2021, 01:49 PM
Last Post: KNERD
  Kernel Update Channel Zweitaktmotor 2 5,805 01-06-2021, 08:22 PM
Last Post: Korac
  Copy To SD Card, All I get Is Red Light & Black Screen . . . . NobodyNew1 9 17,932 09-13-2020, 08:59 PM
Last Post: NobodyNew1
