Kernel panics on Youtube
For a couple of weeks now, my Pinebook Pro gets into frequent kernel panics.
The most noticable activity going on at those time is Youtube playing long clips.
At first, I thought it was the NVMe drive overheating, so I set the laptop on a cooling pad.
The kernel panics still occur even though the temp is low (I keep Psensor on the screen foreground).
This page suggest rebuilding the initramfs but I am wary of these kind of operations.
My unit is running the stock Manjaro distribution.
Can anyone propose a troubleshooting course?
Cheers,
Solostian
I'm seeing similar reboot issues with my Pinebook Pro that has the original Debian on it. I suspect in my case the issue might be related to heat; video playback seems to cause the CPU to spike to max frequency, resulting in a lot of power usage/heat generated, and I don't think the hardware design dissipates it quick enough. As a work around, I've started clamping the max frequency at 1.01ghz.. doesn't seem to affect the video playback at 480p at least..
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,800 01-22-2023, 10:05 PM
Last Post: rfm83
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 8,978 01-22-2023, 09:55 PM
Last Post: rfm83
  minimal kernel .config? alchemist 5 11,020 08-15-2022, 06:28 PM
Last Post: svmhdvn
  How is youtube and general web browsing on the PineBook Pro? catloaf 4 7,608 06-22-2022, 01:49 PM
Last Post: gravedigger
  Content Streaming on the Pinebook Pro! (Netflix, Spotify, Crunchyroll, YouTube!) ImmyChan 1 4,822 10-07-2021, 11:42 PM
  Screen refresh delay with kernel errors shawnanastasio 31 63,684 04-27-2021, 02:57 AM
Last Post: james64
  I/O errors from SD card slot? (Manjaro, kernel 5.7) zackw 5 15,055 10-28-2020, 01:16 AM
Last Post: 25519
  mhwd-kernel: command not found motezart 1 6,357 10-16-2020, 03:11 PM
  Boot custom kernel on PineBook Pro lowenware 7 15,336 07-06-2020, 03:31 PM
Last Post: lowenware
  Youtube audio stopped fuctoning Moon1 0 2,917 02-14-2020, 12:12 AM
Last Post: Moon1
