open on-screen keyboard at will
hi :-)
applications like gvncviewer dont offer visible options to open the on-screen keyboard.
is there a way to open it?
maybe through the bar at the bottom?
kind regards
(06-11-2021, 03:21 PM)yogo1212 Wrote: hi :-)
It would be hugely advantageous to be able to pop up the keyboard at will.  Surely there could be some way to do that?
On Gnome you can just swipe up, and on Phosh and Windows 8/8.1/10 you can press the on-screen keyboard button.
Would be nice if something like either of those would be possible on Plasma (both desktop and mobile).
母語は日本語ですが、英語も喋れます(ry
  screen brightness Uturn 1 4,368 10-09-2023, 04:38 AM
Last Post: Eugo
  Manjaro: Settings doesnt open nbh 0 3,372 09-24-2023, 05:25 PM
Last Post: nbh
  screen brightness locked Uturn 0 3,247 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,597 02-24-2023, 12:56 PM
Last Post: jakfish
  No keyboard in Signal Desktop Kimberley van Buyten 4 6,862 10-16-2022, 10:25 AM
Last Post: Eugo
  Screen timeout makes alarm and timer unusable... Eugo 9 11,913 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 5,464 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 16,515 09-05-2022, 03:50 PM
Last Post: christev1
  Where do the keyboard layouts go? Eugo 1 3,049 08-31-2022, 11:03 AM
Last Post: Eugo
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 2,709 07-04-2022, 11:42 AM
Last Post: tuxmain
